tzCAjAL
Temperature and humidity sensor
The temperature and humidity sensor module v1.0
module function
module supports DHT11, DHT12 sensors, and sht30 with iic interface, providing high-precision temperature and humidity data;
the core chip uses ESP266.
Smartconfig can be used to configure the network;
it supports OLED screen to directly display temperature Display of humidity data and network time; iic screen.
The module itself has a serial port interface and supports serial port output;
the open source code is onenet's mqtt;
for relevant information, you need to watch the video on station b.
Customized temperature and humidity sensor-the male model is really easy to use_bilibili_bilibili
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 11:11:19
  • 430 serial port problem, please advise
  • Autonomous navigation chassis
  • Hi3518 Rebirth (Part 3) http+mjpeg bug fix in minihttp
  • Problem choosing direction? I’m in a hurry!!
  • Main technical indicators of the antenna
  • Prepare MCU 12864 Dynamic waveform display Original personal test
