OxCqzhu4u
PD power top plate
With it you will get 1×PD input low-power buck-boost power supply (OUT MAX: 40V 40W) 1×PWM generator 1×voltage ammeter
can be set to decoy 5V, 9V, 12V, 15V, 20V all PD power supply
3.5*6cm The mini size
has a huge screen-to-body ratio (fog),
which is really a good thing.
(It is a bit hot when running)
This project consists of two projects, this project is the roof. For the driver, see the attachment . The
bottom board connection is: https://oshwhub.com/surpmotherfucker/pd-newcurr
Note: Before using its ammeter function, please connect the OUT+ points of the two boards with wires, otherwise the voltage drop will be large and the current value will be inaccurate.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 22:54:53
  • PS2 Protocol
  • MPLAB compiler failed
  • Function of the isolating switch
  • STM32103vet6 cannot read RAM?
  • The LIS2MDL array board welding of the magnetic nail navigation AGV car is completed
  • Graduation project help~~urgent~~!!
