TcKxGb5
ESP32 Programmer-6P
I made an ESP32 programmer using CH340, which can be connected to a 6-pin 2.54-pitch probe.
PDF_ESP32 Burner - 6P.zip
Altium_ESP32 Burner - 6P.zip
PADS_ESP32 Burner - 6P.zip
BOM_ESP32 Burner-6P.xlsx
93701
ESP32C3_WLED_LAMP
This is a circular colored LED light panel designed using the ESP32C3, which can be embedded into the Tuozhu LAMP001 model and used as a colored light source.
A colored light panel was designed that can be embedded into the lamp001 bamboo table lamp model.
One LED in the initial version was not grounded; this has been corrected in the source code.
The firmware is written in MicroPython; related software can be found on GitHub: https://github.com/piaoxuebingfeng/esp32c3_mpy
PDF_ESP32C3_WLED_LAMP.zip
Altium_ESP32C3_WLED_LAMP.zip
PADS_ESP32C3_WLED_LAMP.zip
BOM_ESP32C3_WLED_LAMP.xlsx
93702
STC8H8K64U-LQFP32 Development Board
The main controller uses STC8H8K64U-LQFP32, with all GPIO pins brought out. It has a power indicator, a programming and power button (which can also be used for restarting), two onboard user buttons, two LEDs, and a WS2812 LED for basic input/output practice. It has an IIC pin header, and there is enough space to insert a 0.91-inch OLED display screen for practicing IIC communication and displaying simple information.
VID_20240716_175627.mp4
main.hex
PDF_STC8H8K64U-LQFP32 development board.zip
Altium_STC8H8K64U-LQFP32 development board.zip
PADS_STC8H8K64U-LQFP32 development board.zip
BOM_STC8H8K64U-LQFP32 Development Board.xlsx
93703
#Training Camp# GD32 Simple Oscilloscope
The design of a simple oscilloscope.
Based on the training camp tutorial, we used LCSC EDA for hardware design, SW for casing design, and then built a simple oscilloscope using GD32.
Knob.STL
Shell.STL
Front cover .STL
Screen support rod.STL
Button lever.STL
PDF_#Training Camp#GD32 Simple Oscilloscope.zip
Altium_#Training Camp#GD32 Simple Oscilloscope.zip
PADS_#Training Camp#GD32 Simple Oscilloscope.zip
BOM_#Training Camp#GD32 Simple Oscilloscope.xlsx
93704
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 08:16:02
