INNX0
LM1875 power amplifier board
The LM1875 is a power amplifier integrated circuit developed by National Semiconductor. This device features a small package, simple peripheral circuitry, and excellent overload protection, making it suitable for use as an audio power amplifier in audio systems.
The LM1875 incorporates internal overload, overheat, and inductive load reverse potential protection, ensuring stable operation under various conditions.
This circuit utilizes a dual-channel LM1875T 20W audio power amplifier.
A π-type filter circuit is used at the power input.
The power supply is a 12-24V DC-DC converter.
A 24V 3A or higher power supply is recommended.
[IMG0.jpg]
[IMG1.jpg]
[IMG2.jpg]
BOM.xlsx
PDF_LM1875 power amplifier board.zip
Altium_LM1875 power amplifier board.zip
PADS_LM1875 power amplifier board.zip
BOM_LM1875 power amplifier board.xlsx
95776
Touchscreen stand light
The touch-sensitive stand light has adjustable brightness and can be stood upright using a casing or inserted into some stand bases.
This is a touch-sensitive stand light using the RH6618A chip. It has adjustable brightness and can be stood upright in its casing or inserted into stand bases. However, two LEDs are not working, and I don't know why. The 3D-printed casing isn't very transparent, possibly due to the material chosen. Also, I forgot to include a hole for the switch in the casing design, and the battery hole wasn't deep enough (embarrassing).
4b2e7cea33ff50415f5b68596ded8d19.mp4
c9ef46579bbb02d1e8d18752a3caf4f3.mp4
PDF_Touchscreen Stand Light.zip
Altium Touchscreen Stand Light.zip
PADS_Touchscreen Stand Light.zip
BOM_Touchscreen Stand Light.xlsx
95777
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 01:10:46
  • [Date with Spring] A war started by a lollipop
  • "ADI Analog University" Basics of Power Management (March 9, 2014)
  • Help: imp809 alternatives
  • How to identify S5pv210 dual-channel discontinuous memory in Android/Linux?
  • LDO Quick Reference Guide
  • Invite enthusiastic netizens to build eeWorld together
