fHUtbOFQN
Dual-motor encoder trolley control board (direct plug-in WheelFun Technology TB6612 driver board D153C)
Two-way motor and encoder trolley control board (direct plug-in WheelFun Technology TB6612 driver board D153C)
Main controller: STM32F103C8T6
Peripherals:
Motors*2
Hall encoders*2 USART*1 IIC*2 SWD download port*1
Power indicator*1
With Bluetooth remote control code controllable LED*1
Buttons*3
IMG_1933.MP4
PDF_Two-way motor with encoder trolley control board (direct plug-in WheelFun Technology TB6612 driver board D153C).zip
Altium dual-motor encoder trolley control board (direct plug-in WheelFun Technology TB6612 driver board D153C). zip
PADS dual-motor trolley control board with encoder (direct plug-in WheelFun Technology TB6612 driver board D153C). zip
BOM_Dual-motor trolley control board with encoder (direct plug-in WheelFun Technology TB6612 driver board D153C).xlsx
96604
Four-channel motor control board with encoder (direct plug-in WheelFun Technology TB6612 driver board D24A)
 Four-channel motor and encoder trolley control board (direct plug-in WheelFun Technology TB6612 driver board D24A) Main controller: STM32F103C8T6
Peripherals:
Motors*4
Hall encoders*4 USART*1 IIC*1 PS2 remote control interface*1 SWD download port*1
Power indicator*1
Controllable LED*1
PDF_Four-channel motor and encoder control board for a small car (direct plug-in WheelFun Technology TB6612 driver board D24A).zip
Altium 4-channel motor with encoder control board for small vehicles (direct plug-in WheelFun Technology TB6612 driver board D24A). zip
PADS Four-Channel Motor with Encoder Car Control Board (Direct Plug-in WheelFun Technology TB6612 Driver Board D24A).zip
96605
Color silkscreen PCB heated mouse pad
Heated mouse pads give you a warm winter
       This self-designed heated mousepad uses a PCB-based heating unit and JLCPCB's color silkscreen printing technology. Powered by a mobile phone charger, it's both aesthetically pleasing and practical. The heating pad designed for this project has a power output of approximately 6W. I embedded it in a solid wood board, flush with the board surface. A Type-C female connector is then installed on the side for power with a 2A or higher charger. Alternatively, you can place it under a regular mousepad, with the power supply either led out via a wire or soldered directly onto the board. This mousepad, made with solid wood and a PCB, is much more environmentally friendly than those artificial leather heated mousepads sold online, making it especially suitable for long-term indoor use.
       Placing a regular mousepad on top of the PCB provides a better feel and better heat retention, with the surface temperature remaining around 35-40 degrees Celsius, which is very comfortable. To prevent the risk of overheating from prolonged power-on, it's best to fix a normally closed 55-degree temperature control switch on the back of the PCB using silicone. The product model from JLCPCB's online store is provided in the schematic diagram for reference.
PDF_Color Silkscreen PCB Heated Mouse Pad.zip
Altium Color Silkscreen PCB Heated Mouse Pad.zip
PADS_Color Silkscreen PCB Heated Mouse Pad.zip
BOM_Color Silkscreen PCB Heated Mouse Pad.xlsx
96606
Pure digital circuit clocks and alarm clocks
A purely digital clock and alarm clock, 24-hour system, precise second-by-second operation, and an alarm that sounds when the set time is reached.
This is a purely digital clock and alarm clock,
both using CD4000 series CMOS chips
with a common cathode. The 0.56-inch digital display
uses a 32768Hz crystal oscillator and frequency divider to form an oscillation circuit
, allowing for time calibration, pausing the seconds, setting the alarm time, and turning the alarm off.
The operating voltage is 5V; do not exceed this voltage.
There is no reverse connection protection; reverse connection will burn out the circuit.
The PCB size is 10*10mm, and it meets the free opportunity requirement with
16 0603 surface-mount pull-down resistors
. The PCB traces are loose; only each component is connected.
This has been verified.
Final product effect.mp4
PDF_Pure Digital Circuit Clock and Alarm Clock.zip
Altium_Pure Digital Circuit Clock and Alarm Clock.zip
PADS_Pure Digital Circuit Clock and Alarm Clock.zip
BOM_Pure Digital Circuit Clocks and Alarm Clocks.xlsx
96607
Cinnamon Dog Light
Because I personally like Cinnamon Dog, but there are very few open-source projects related to Cinnamon Dog, I drew one myself.
A flowing light effect was achieved by using an NE555 timer to construct a multivibrator to drive a CD4017 decimal counter.
A breathing light effect was achieved by using an LM358 operational amplifier and peripheral circuitry to construct a triangular wave signal generator. The
flowing light effect was not ideal due to incorrect LED placement.
The breathing light effect was mediocre due to a lack of suitable capacitors.
There were errors in the panel design (now corrected).
WeChat_20231228202520.mp4
PDF_Cinnamon Dog Lighting.zip
Altium_Cinnamon Dog Lights.zip
PADS_Cinnamon Dog Lighting.zip
BOM_Yu Gui Gou Lighting.xlsx
96609
daplink
DAPlink Download Debugger
The STM32F103C8T6 chip has been tested and is working. Use J-Link-Flash to program the STM32F103XB_BL.Hex file. After inserting the USB drive into your computer, a new USB drive will appear; open it and copy the STM32F103XB_IF.Hex file to the USB drive. This was the first board I built, and there were some errors; this version has corrected them.
stm32f103xb_bl.hex
stm32f103xb_if.hex
PDF_daplink.zip
Altium_daplink.zip
PADS_daplink.zip
BOM_daplink.xlsx
96610
Ziyi Technology makes the Year of the Dragon mascot cool and stylish.
It is an ambient light developed based on the 51 microcontroller, featuring a dragon mascot (Long Chenchen). The lights around the dragon will flash rhythmically in sync with the music emitted by the buzzer!
Engineering Principle: A cool dragon mascot was created using the STC89C52RC chip. The main design concept is to use the surrounding atmosphere and the lights around the dragon mascot as rhythm lights, because once the music mode is switched, it will flash in rhythm with the music!
Of course, this design can be optimized even better. Mainly because I am not very good at software (programming), I used two STC89C52RC chips for control!
3DShell_The Year of the Dragon Mascot is Cool.zip
The Year of the Dragon mascot is getting cool.mp4
PDF_Ziyi Technology Makes the Year of the Dragon Mascot Cool.zip
Altium_Ziyi Technology makes the Year of the Dragon mascot cool. (zip)
PADS_Ziyi Technology makes the Year of the Dragon mascot cool and stylish. (zip)
BOM_Ziyi Technology makes the Year of the Dragon mascot cool and stylish.xlsx
96611
CH9141K Bluetooth serial port
The BLE Bluetooth serial port made using CH9141K comes with a built-in reverse connection protection/AT configuration switch, making it a replacement for other Bluetooth serial ports that are difficult to configure.
⚠️Note that
this project was designed using KiCad v6 (a very old project), so there is no unconditional free PCB fabrication service available with lCad. The schematic preview is at the bottom, please take note.
If you want to fabricate a PCB, please use Gerber below. The PCB in lCad is imported and is for preview only. The BOM is also below. Please do not use the automatically exported version. For the
PCB, please use a 1.2mm board thickness.
It's just a BLE Bluetooth serial port, easy to solder and use. It has a built-in reverse connection protection/AT configuration switch.
When using it, just be sure to modify the BLE pass-through parameters.
Schematic
test images are included.
Gerber_CH9141K_V1_1.zip
PCB_CH9141K.zip
ibom.html
Schematic diagram CH9141K.pdf
PDF_CH9141K Bluetooth Serial Port.zip
Altium_CH9141K Bluetooth serial port.zip
BOM_CH9141K Bluetooth Serial Port.xlsx
96612
Open source AR glasses
OSAR is an AR glasses device that is easy to replicate, functional, and cost around 1000 RMB. We welcome contributions from talented individuals to the project.
1.1 Overall Overview
Chapter 1 provides an overview of the project, naturally introducing the assembly method of the optical components.
Chapter 2 details the AR circuitry and programming.
Chapter 3 introduces the current project status.
The entire production process involves assembling the optical components first, aligning them with the screen, and then burning the hardware circuitry into the firmware.
1.2 Features
OSAR leans towards exploration and features a 1920x1080 OLED display. The upper part is a detachable
thermal imaging module; after removal, an infrared camera is found inside.
This is the anime viewing function:
This is the gesture recognition demo (based on midiapipe):
1.3 Motherboard Principles
To drive the display, a computing platform is required. Initially, I tried driving
the display directly from a mobile phone (using the phone's HDMI output), but my self-developed application couldn't access the infrared
camera . Without the infrared camera, the night vision device and my self-made application wouldn't work. I also tried
a development board I designed myself, using JLCPCB's six-layer immersion gold process, running Linux. It drove the optical components without
problems , but it couldn't run Android AR applications, meaning I couldn't see stars or perform measurements. So, is there
a compatible and feature-rich solution? I thought of the embedded Android module commonly used in these advertising machines:
the RK3399, the one shown in the video. Over time, I purchased
the Thunderbird Air AR glasses, which are currently on the market. After market research, I believe that the AR industry in 2024 doesn't
need to be too ambitious, running an Android system with every function to replace a phone. Instead, it should focus on a single, specialized
function, adopting a B2B approach, and becoming a necessity in specific situations. The reason is simple: hardware computing power
and battery life are insufficient, making this approach suitable. Below is the architecture diagram:
you'll find that AR glasses are essentially just a display with a camera attached to the face, so
connecting to phones, computers, and development boards, including Raspberry Pi, is not a problem. I also used
Raspberry Pi during early testing (how did I end up playing with all the development boards??). Now I've chosen to modify the H6
16-based Yuzuki Pi, as this offers the highest cost-effectiveness, helping you achieve your
core needs—watching anime, thermal imaging/fusion, and night vision—at minimal cost. In other words, it's both practical and cool. For a
thermal imaging tutorial, please see the attached doc file. Available motherboard images:
https://115.com/s/swzzh0c33g7?password=k716&#https://115.com/s/swzzw6a33g7?password=l2c0
Detailed motherboard information can be found in the PCB section of the project. An HDMI adapter circuit is essential; otherwise, it won't work.
I personally recommend using JLCPCB SMT, as it's difficult to solder the three BGAs on the motherboard successfully on the first attempt.
1.4 Display Section
If you wish to assemble it, please refer to section 1.4.2 for the animated disassembly or the attached video. The blue component at the bottom is
the lens (a combination of a convex lens and a semi-transparent, semi-reflective lens).
1.4.1 Lens Principle
With the screen so close to our eyes, can we really see clearly? The lens in our eyes automatically adjusts its focusing distance,
allowing us to see objects clearly. However, if the distance is too close, it exceeds the eye's focusing ability, meaning we can't see clearly.
VR's solution is to add a lens in front of the screen, making your eyes perceive objects as far away. AR,
based on the same principle, adds a semi-transparent, semi-reflective coating, thus achieving a
superimposed .
1.4.2 Assembly
The key component, the optical lens, can be easily purchased on Xianyu (a second-hand marketplace). After purchasing, you need to
remove the LCOS (Liquid Optical Coating) component. There is no open-source driver available for the LCOS. Replace it with your
own ECX335 screen. Screens can be purchased on Taobao for under 850 RMB.
The middle section contains the eyeglass frame, OLED panel, and driver board (model ECX335AF). Above is the camera and its support
. The first step of assembly is installing the camera and lens onto their respective supports (model OV5647 (IR))
. The second step involves installing the ECX335 in the lower section, precisely aligned with the lens's imaging portion.
The driver board is installed in the upper section. The FPC cables for both are not shown in the image, but please handle them carefully during the
final step. The upper and lower sections are then glued together; AB glue is recommended. After gluing, connect the HDMI and USB cables.
The display effect is as shown: no purple fringing or distortion, but the FOV is small, and the brightness is around 300 nits.
The weight before and after assembly is 67g, which is acceptable.
1.5 Open Source License:
This project is under the MIT license. Commercial development does not require authorization, but the original author's logo and name cannot be used.
1.6 Project Attributes:
This project is being publicly released for the first time and is my original work. This project has not won any awards in other competitions.
1.7 Reference:
Yuzuki Chameleon H616-based Card Computer - JLCPCB EDA Open Source Hardware Platform (oshwhub.com).
The motherboard is modified from Yuzuki Pi, with USB, HDMI, audio, and Ethernet
replaced with onboard interfaces suitable for small spaces. The crystal oscillator part number was modified to match the LCPCB online store.
1.8 Thermal Imaging:
Thermal imaging is essentially a type of camera. Consumer-grade thermal imaging commonly uses USB running the UVC protocol. UVC
is simpler; various software programs can decode it, even without writing your own program. The advantage of my publicly disclosed
method is its low cost, making it more user-friendly for enthusiasts, since it involves buying secondhand goods (laughs). Due to
the large amount of content, I have made it into a separate doc attachment; please download and view it.
2.1 To program OSAR,
you need a TF card reader and an 8GB card.
Image from cv6851453. The hardware connection method is described below:
Because the hardware was given away (as mentioned above), I will explain the specific operation process with pictures and text here.
External power supply means you can directly connect a power bank or charger. A USB camera is not mandatory, but
connect it if you have one. Connecting it allows for some interactive development.
The connection method is D- D+ 5V GND from top to bottom. If you need lithium battery power, you can try
connecting the lithium battery directly to the mains (PS and GND). A TF card is required; otherwise, it will draw power from the built-in e-emulator.
MC boot. The connector in the bottom right corner for the OLED screen refers to the ECX335 driver board. You just need to buy a regular
HDMI to Micro HDMI cable and
connect the driver board (available on Taobao) to the motherboard using an HDMI cable (see picture below). Remember to handle the FPC cable carefully.
After connecting, you will see the system screen. At this point, playing movies and acting as a monitor are no problem
. The assembly of the optical components can skip to section 1.4.2. This section covers the assembly of the circuitry and system flashing.
If you feel that leaving the motherboard exposed is too dangerous,
you can do what I did: disassemble an Iron Man suit of clothing, install the battery and motherboard inside,
and then attach it to the suit with a magnet.
This is similar to mainstream AR glasses on the market, allowing users to watch anime and satisfy entertainment needs.
Hopefully, this helps you understand why I said, "AR isn't mysterious; it's like a phone or computer—it accepts
user data input, processes the data through pre-written programs, and finally outputs the results
to the user. The only difference is that AR's display system is more advanced."
3.1 Future Outlook
: I have some good news! The littleAR project has secured investment and plans to produce a mass-produced device by the middle of next year.
I'm also developing a new generation of waveguide-based AR systems, as shown in the image above. Talented individuals are welcome to join us.
3D shell OSAR.step
Thermal imaging for 400 yuan.docx
USB camera adapter bracket.
Simple Gesture Recognition Code Reference.zip
A beginner's tutorial that anyone can understand. (mp4)
Build (unity).apk
Combat Power Detection.apk
Map Building (SLAM).apk
Map Building (SLAM).zip
Mapping (SLAM).z01
PDF_Open Source AR Glasses.zip
Altium_Open Source AR Glasses.zip
PADS_Open Source AR Glasses.zip
BOM_Open Source AR Glasses.xlsx
96613
ESP32-C3-FOC
The ESP32-C3-FOC development board uses the ESP32C3 chip as the main controller and supports rapid development of brushless motors using simpleFOC. The power input is 12V.
This document introduces
the ESP32-C3-FOC development board, based on the ESP32C3 WIFI/Bluetooth chip as the main control chip. It enables rapid implementation of sensor-based FOC motor control.
Features include:
12V voltage input,
I2C interface magnetic encoder,
reserved serial ports,
and USB programming support . Pin functions
: GPIO4 Motor pin U, GPIO5 Motor pin V , GPIO6 Motor pin W , GPIO8 I2C SCL , GPIO2 I2C SDA , GPIO7 WS2812 indicator control pin, GPIO9 Boot pin. Development Guide: Development Environment: ESP-IDF: Espressif open-source software framework ; Open-source code: based on Arduino; simpleFOC: Open-source sensor- based FOC motor driver library; esp_simpleFOC: SimpleFOC version developed using ESP-IDF; Example: Open-loop and closed-loop operation based on simple-FOC.
PDF_ESP32-C3-FOC.zip
Altium_ESP32-C3-FOC.zip
PADS_ESP32-C3-FOC.zip
BOM_ESP32-C3-FOC.xlsx
96614
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 12:47:24
