toothache
MAXREFDES77#: Dual-channel current sensing peripheral module
The MAXREFDES77# peripheral module provides the necessary hardware circuitry to allow the MAX44285 dual-channel high- side current- amplifier to be connected to any system configured for SPI communications using a Pmod™-compatible expansion port. The IC has a common-mode input with a voltage range of 2.7V to 76V and a small signal bandwidth of 80kHz. It is ideal for connecting to SAR ADCs and used in multi-channel, multiplexed data acquisition systems.
For detailed operating information on the IC, please refer to the MAX44285 IC data sheet; for detailed information on the Munich circuit board and GUI, please refer to the USB2PMB1# (Munich) adapter circuit board data sheet.
characteristic
  • 2.7V to 76V input common-mode voltage
  • Low input offset voltage of 12µV (max)
  • 0.1% (max) low gain error
  • Gain = 20V/V and 100V/V
  • RoHS compliant
  • Proven PCB layout
  • Fully installed and tested
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 04:09:11
  • Design and production of rocking stick
  • DIY mobile phone + Sur + vibration function
  • Here is a solution to pedal power and longer battery life
  • 【TI recommended course】#MSP432 product training#
  • How to test the controller?
  • Moving, some boards
