4158
Posts
Resources
41
maychang posted on 2022-4-12 20:55 There is a source of error in RC charging and discharging, that is, charging and discharging do not start from the amplitude or zero value, but from the ripple valley value and peak value, and charge to...
From a proportional point of view, the ripple voltage is usually required to be less than 100 times the PWM level, and the capacitor is regarded as a constant voltage source. If even this 1% calculation error is not acceptable, how can we be sure that the waveform can be accurately superimposed?
Personal signature
YesWatt艺瓦特电子科技有限公司
专业定制设计生产适应各种恶劣环境的直流专换器
广泛应用于军警装备 无人机系留 公路直流系统 电厂高压高温设备 特高压输变电数据采集取电等
4158
Posts
Resources
42
To minimize the error, we can only use the method on the 18th floor, rather than using the language
Comments
The method on the 18th floor seems to be calculated using Excel, and it needs to be iterated many times. I don't know if it is calculated in this way. In addition, the method on the 18th floor is not as you said on the 26th floor: "the curve segment can be regarded as a line segment, and the ripple voltage can be regarded as a triangular wave."  Details Published on 2022-4-12 21:20
Personal signature
YesWatt艺瓦特电子科技有限公司
3w
Posts
Resources
43
PowerAnts posted on 2022-4-12 21:03 To minimize the error, we can only use the method on the 18th floor, not the language
The method on the 18th floor seems to be calculated using Excel, and it requires multiple iterations. I don't know if it is calculated this way.
In addition, the method on the 18th floor is not the same as what you said on the 26th floor: "the curve segment can be regarded as a line segment, and the ripple voltage can be regarded as a triangular wave."
Comments
The 18th floor is trying to solve it through RC charge and discharge function, which belongs to Sunshine Avenue and is in the right direction  Details Published on 2022-4-12 21:39
4158
Posts
Resources
44
maychang posted on 2022-4-12 21:20 The method on the 18th floor seems to be calculated using Excel, and it needs to be iterated many times. I don't know if it is calculated in this way. In addition, the method on the 18th floor is not...
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
45
Personal summary, for RC filtering:
1. Sinusoidal circuit, capacitive reactance + Ohm's law, OK!
2. PWM smoothing filter with low ripple rate output, constant voltage charging and discharging of R to C, simple and convenient charge balance, and the accuracy of calculation results is better than the device accuracy, which meets the requirement of no adjustment!
3. In rectangular wave circuit, the RC turning point is several to dozens of times away from the PWM frequency, and the charge and discharge curve is no longer straight. Only by using the exponential function can the peak-to-peak voltage on the capacitor be correctly calculated.
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
46
It's a bit exaggerated. The green line looks like this. Is this a test of Ohm's law?
Comments
"That's a bit exaggerated. The green line is like this. Is Ohm's law playing a trick?" The green line already includes Ohm's law. Whether it is first-order RC or RL, the equations are based on Kirchhoff, such as the blue line in the figure below, and Kirchhoff derived it based on Ohm's law. Then the red line  Details Published on 2022-4-13 17:46
Personal signature
YesWatt艺瓦特电子科技有限公司
3w
Posts
Resources
47
PowerAnts posted on 2022-4-12 22:11 It's a bit exaggerated, the green line is like this, is Ohm's law playing a trick?
"That's a bit exaggerated. The green line is like this. Are you trying to use Ohm's law?"
Whether it is first-order RC or RL, the equations are based on Kirchhoff, such as the blue line in the figure below, and Kirchhoff derived it based on Ohm's law. Then the red line is simply Ohm's law.
Comments
What about capacitance?  Details Published on 2022-4-13 18:22
4158
Posts
Resources
48
maychang posted on 2022-4-13 17:46 "It's a bit exaggerated. The green line is like this. Ohm's law is used for this?" The green line already includes Ohm's law. First-order RC is also good, ...
Comments
The capacitive reactance is actually in the equation behind the red line: i=C*duc/dt. This equation is the definition of capacitance and also shows the capacitive reactance.  Details Published on 2022-4-13 18:45
Personal signature
YesWatt艺瓦特电子科技有限公司
3w
Posts
Resources
49
PowerAnts posted on 2022-4-13 18:22 What about capacitance?
4158
Posts
Resources
You have to go to XX to find HXX to reason with him. On June 13, 2011, I said in a post:
According to Ohm's law, U=IR+Q/C
In a few minutes, HXX posted several posts like a mad dog saying that the above formula is not Ohm's law. I was so angry that I ate two bowls of braised pork to vent my anger.
Comments
"I was so angry that I had to eat two bowls of braised pork to relieve my anger." Ha! Two bowls of braised pork!  Details Published on 2022-4-13 20:01
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
51
If you are interested, you can summarize the situation in your post and compete with HXX to see if he is willing to use Fourier to push up two or three pages.
Personal signature
YesWatt艺瓦特电子科技有限公司
3w
Posts
Resources
52
PowerAnts posted on 2022-4-13 19:36 For this, you have to go to XX to find HXX to reason. On June 13, 2011, I said in a post: According to Ohm's law, U=IR+Q/C. In a few minutes...
"I was so angry that I had to eat two bowls of braised pork to vent my anger."
4158
Posts
Resources
53
maychang posted on 2022-4-13 20:01 "I was so angry that I had to eat two bowls of braised pork to get rid of my anger." Ha! Two bowls of braised pork!
Here are my two screenshots:
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
54
Speaking of braised pork, half a year ago the doctor told me that I must start taking Baixintong for life, but I refused because I knew there were other ways. I only controlled my salt intake and my blood pressure dropped from 160/110 to 120/80. I can still eat braised pork, twice-cooked pork and eggs as usual.
In the past two years, I used to feel dizzy when I was having sex, but now I don't feel dizzy at all.
Few people know that if a person survives by eating only cabbage and boiled noodles in water (without adding anything else), his sodium intake will exceed the standard by twice.
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
55
This is also blocked! ?
Personal signature
YesWatt艺瓦特电子科技有限公司
Posts
Resources
56
I'm here to study too.
27
Posts
Resources
57
XC=1/(ωC), when the frequency is very low, the capacitive reactance of the capacitor is large, equivalent to an open circuit, UI is approximately equal to UO, when the frequency is very high, the capacitive reactance of the capacitor is very small, equivalent to a short circuit, UO≈0.
4158
Posts
Resources
58
Ming8686 Published on 2022-4-15 14:12 XC=1/(ωC), when the frequency is very low, the capacitive reactance of the capacitor is large, which is equivalent to an open circuit, and UI is approximately equal to UO. When the frequency is very high, the capacitor's...
In another place, Mr. Yao from STC gave some suggestions. They did this
Without evaluating the same second-order cascade, it is worth learning how to solve the problem of voltage floating under load by feeding back to the ADC closed-loop output.
Personal signature
YesWatt艺瓦特电子科技有限公司
4158
Posts
Resources
59
This is the benefit of interaction. Without benefit, it cannot be sustainable! A sudden enlightenment is worth 1,000 gold coins. I would rather spend my own money to reward
Personal signature
YesWatt艺瓦特电子科技有限公司
419
Posts
Resources
I guess I am still confused by what you guys are discussing, as you haven't solved his question about Vout=VCC*Duty.
I'll give you something that LZ can understand.
Only look at the steady state, the steady-state capacitor charge balance (charging equals discharging)
(VCC-Vout)*Duty/R=Vout*(1-Duty)/R
So Vout=VCC*Duty
As for transient state, details, and trial conditions, see the discussion above.
Guess Your Favourite
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
