RC filter circuit b
Source: InternetPublisher:smallembedded Keywords: Filter circuit RC filter BSP Updated: 2020/09/15
On some occasions. If the load current is not large, in order to reduce weight, cost and size,
the L on the above two compound filters can be replaced with a resistor to form an RC type filter and an RC-7r type filter, as shown in the figure. Show.
In the RC filter , a large R has a good filtering effect, but the voltage drop loss on the resistor is also large. Generally, in the case of small current, the resistor is usually tens
to hundreds of ohms, and the capacitor is several hundred microfarads (200yF, 5001uF).
After rectification, a filter capacitor needs to be added. The capacity of the filter capacitor needs to be selected according to the size of the electrical load, usually from tens of microfarads to hundreds of microfarads
. Some DC power supplies with higher requirements also need to add an integrated voltage regulator for voltage stabilization to obtain a high-quality regulated power supply with smaller ripples.
The relationship between filter capacitor capacity and load current is shown in Table 12-2. The size of the filter capacitor can be selected according to the output current .
- Analysis of the working principle of switching regulator
- Basic connection circuit of signal and power supply composed of ISOll3
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Detailed explanation of 5v charger circuit diagram
- A simple positive and negative power supply circuit
- LM317 regulated power supply
- Adjustable voltage power socket
- Constant current charger using light emitting diode as voltage regulator
- UC3842 Electric Vehicle Charger
- Converting a lithium battery charging board into a constant voltage and current charger
- stuttering correction circuit
- Bone hyperplasia treatment circuit
- Peanut and melon seeds roasting machine circuit
- Junction field effect transistor mixer circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Digital stopwatch display circuit
