The OP
Published on 2010-3-15 22:59
Only look at the author
This post is from stm32/stm8
Latest reply
In addition, since this library will disable interrupts when measuring charge and discharge time, it is not suitable for applications that require high interrupt response, such as simulating SIP interfaces.
The RC library will turn off interrupts when measuring charge and discharge time. There is no way to solve this problem. Only by turning off interrupts can the charge and discharge time be accurately measured. To solve this problem, you can consider using the STM8L touch library, which is said to be able to overcome this problem.
Details
Published on 2010-4-16 10:04
Published on 2010-3-16 18:57
urmysuperstar
Currently offline
Published on 2010-3-16 19:58
Published on 2010-3-17 12:22
Published on 2010-3-17 16:51
haxinglong
Currently offline
Published on 2010-3-17 17:36
Published on 2010-3-17 21:07
Published on 2010-3-17 21:53
Published on 2010-3-18 14:33
Published on 2010-4-15 12:19
Published on 2010-4-15 14:14
Published on 2010-4-15 19:59
Published on 2010-4-15 21:12
Published on 2010-4-15 23:11
EEWorld Datasheet Technical Support
Room 1530, Zhongguancun MOOC Times Building,
Block B, 18 Zhongguancun Street, Haidian District,
Beijing 100190, China
Tel:(010)82350740
Postcode:100190
京公网安备 11010802033920号
