6415 views|8 replies
45
Posts
Resources
The OP
1V voltage drop circuit [Copy link]
I need to reduce the voltage from 5V to 4V, and the supply current changes from 80mA to 2A. Using a single diode, it is only 0.7V, but using two diodes, it is over 1.4V. Please help me how to achieve this without using DC-DC. Thank you!
This post is from Analog electronics
Latest reply
I don't know which of the following purposes is this? ①. I just want to reduce the power supply by 1V - if the power supply voltage changes from 5.2V to 4.8V due to the load, the output also changes from 4.2V to 3.8V. ②. I hope the output is stable at 4V. ③. The output is almost 4V, and the accuracy does not matter. If ③: It is the simplest to connect silicon diodes in series. If ②: Find a linear voltage regulator that can withstand more than 2A. If ①: It is also a linear step-down, but the reference point of the feedback is not to the ground, but to the power supply (see the picture).  Details Published on 2013-2-23 01:04
45
Posts
Resources
Where are the big hands :)
Posts
Resources
Two diodes 1N4001 and 1N5819
2w
Posts
328
Resources
The 1V step-down voltage of the original poster is not so high. If you don’t mind the trouble, I recommend you TI’s LMR10520. The schematic diagram is for reference only!
1w
Posts
23
Resources
As for 5V and 4V, the voltage difference is small, and the efficiency of using a switching power supply is not superior to that of an LDO; and the switching type is more expensive than an LDO, and has additional interference. Therefore, it is more appropriate to use an LDO. I think the original poster should open up other ideas, such as why it must be a 5V input and why it must be a 4V device.
45
Posts
Resources
DC-DC is not used due to cost considerations, and the voltage is also fixed because they are all modular devices. When the current increases, the diode voltage drop increases slightly, and basically remains at around 4.3-4.2. The module recommends a power supply of 4V, and the requirement is between 3.6-4.5, but there is a large overshoot at the moment of power-on, which can reach around 4.8V. The post-stage also has a large electrolytic
Comments
Is the GSM module used?  Details Published on 2013-2-22 12:40
1w
Posts
23
Resources
1w
Posts
132
Resources
Silicon tube series Schottky tube
3122
Posts
Resources
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Room 1530, Zhongguancun MOOC Times Building, Block B, 18 Zhongguancun Street, Haidian District, Beijing 100190, China Tel:(010)82350740 Postcode:100190
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
