2397 views|1 replies
Posts
Resources
The OP
TL3016 High-Speed Comparator [Copy link]
The dual-supply comparator is powered by a single power supply. The -VCC ground power supply operates at 2.4 - 3.3 V. If it is out of range, it will not work and there will be no waveform output. What's going on?
This post is from Analog electronics
Latest reply
"The power supply works outside the range of 2.4 - 3.3 V and does not work." What is the input signal amplitude? This chip has requirements for the input signal amplitude. [attach]250457[/attach]   Details Published on 2016-7-27 19:48
3w
Posts
Resources
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
