Home > Other > TLV3501 comparator circuit schematic, parameter packaging and application
Source: InternetPublisher:三岁就很酷 Updated: 2021/03/05
TLV3501 circuit description:
The TLV350x series of push-pull output comparators, have fast delay times from 4.5ns propagation delay and operate from +2.7V to +5.5V, making them ideal for low-voltage applications due to the over-the-rail input common-mode range. Rail-to-rail outputs can directly drive CMOS or TTL logic.
The Microsize package provides options for portable and space-constrained applications. Single (TLV3501) is available in SOT23-6 and SO-8 packages. Dual (TLV3502) comes in SOT23-8 and SO-8 packages.
TLV3501 circuit diagram:
TLV3501 circuit parameters:
High speed: 4.5ns
Rail-to-rail input/output
Supply voltage: 2.7 V to 5.5 V
Push-pull CMOS output stage
Shutdown function (unique to TLV3501)
Micro package: 6-pin SOT-23 (single), 8-pin SOT-23 (dual)
Low power consumption current: 3.2mA
TLV3501 package type: SOIC8
TLV3501 circuit applications: signal generator (vector signal generator - VSG), motor control: permanent magnet, motor control: AC induction, oscilloscope (DSO), motor control: high voltage, dialyzer, etc.
