Current relay secondary starting circuit
Source: InternetPublisher:containsmachine Keywords: Current relay starting circuit BSP Updated: 2020/04/08
160. The circuit is shown in Figure 3-160. This circuit uses a current relay to control the resistance value in the rotor winding, changes
the rotor current, and starts the motor in stages.
In the figure, Ri and Rz are resistors for graded starting. The first-level starting current is detected by the current relay KIl connected in series with Ri , and the second-level starting current is detected by the current relay
KIz
connected in series with Ri . Since the first-stage starting current
is larger than the second-stage starting current, the release current of KL should be made larger than the release current of KIz during setting. They have the same pull-in current.
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Perform surgery on the speaker protection circuit
- A small improvement on the ordinary refrigerator motor starting circuit
- Manual automatic air compressor control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Using P110C to control 6 DC motors simultaneously
- Temperature control circuit design and analysis
- Design and manufacture of three-phase motor protection circuit
- An experimental model of an infrared radio alarm
- Homemade short circuit alarm device
- Voice controlled flash LED light circuit diagram
- strain sensor
- Electronic anti-asthma circuit
- Rice mill circuit
- Soil water shortage prompt circuit
- Simple AGC circuit in transistor radio
- Amplitude modulation circuit composed of MC1496
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
