Simple AGC circuit in transistor radio
Source: InternetPublisher:zht24 Keywords: Transistor radio AGC circuit BSP detector Updated: 2020/09/06
Peak envelope detection requires that the input high-frequency signal is relatively large, and the amplitude should be greater than 0. 5v, so it is also called a large signal peak envelope detector . According to
the connection method of the diodes in the envelope detection circuit, the envelope detection circuit is divided into series peak envelope detector and parallel peak envelope detector.
The series peak envelope detector
consists of an input loop, a diode VD and an RC low-pass filter.
The diode peak envelope detector with a simple AGC circuit is shown in the figure. Diode VD
adopts 2AI-9.
RP1 and G form a low-pass filter of a simple AGC circuit
The slowly varying DC component is taken out from the detected audio signal as a control
signal to directly control the gain of the transistor. It can be seen from the analysis
that the larger the signal, the larger the DC component after detection, and
the smaller the collector current of the IF amplifier transistor, so this automatic gain
control circuit should be a reverse AGC. Adjusting the variable resistor RP1 can
make the cutoff frequency of the low-pass filter lower than
the lowest frequency of the demodulated audio signal to avoid reverse modulation.
- The main characteristics, advantages and disadvantages of IoT protocols
- Wireless transmission of integrated TV signals for amateur productions
- Production of a FM wireless microphone
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- MAX2820/MAX2821 I/Q 2.5-2.4 GHz Transceivers
- RXM-921/916/903/868/433-ES Series Receiver Modules
- WE800 FM/FSK 1~0.1 GHz Transmitter
- DKl000R OOK 315 MHz Receiver Module
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Fish pond oxygenation reminder circuit
- Frequency modulator composed of NE566
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode square rate detection circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage series negative feedback amplifier circuit
- AGC circuit with CMOS logic
- AM receiver AGC circuit
