An example of LC oscillation circuit
Source: InternetPublisher:三岁就很酷 Keywords: Oscillation circuit LC circuit Updated: 2024/10/30
The LC oscillation circuit is as follows:
LC Circuit:
This circuit is also called a resonant circuit, a tank circuit or a tuned circuit. It is a circuit that consists of an inductor (represented by the letter L) and a capacitor (represented by the letter C) connected together.
Circuit function:
The circuit can be used as an electrical resonator (an electrical analog of a tuning fork), storing energy from oscillations when the circuit resonates.
- Production of 74HC00 multivibrator
- Multivibrator circuit experiment based on 4069
- AD585 12bit A/D conversion system circuit
- 50~1000kHz transistor oscillator
- 1kHz to 1MHz sinusoidal oscillator circuit
- RC bridge oscillator and its equivalent circuit
- 20~20000Hz low distortion audio oscillation circuit
- 10/1 frequency range function oscillator
- Logarithmic swept voltage controlled oscillator
- 800Hz single transistor oscillation circuit
- Seven basic analog circuits
- Low distortion oscillator circuit using varactor diode b
- Bias and degaussing oscillation circuit of monophonic recorder
- Optocoupler controlled oscillator circuit
- Crystal oscillator circuit composed of "OR" gate
- Simple sinusoidal oscillator circuit using op amp
- Oscillation circuit diagram
- Resistor-capacitor oscillation circuit
- Negative resistance light emitting diode oscillation circuit
- Liquid temperature uniform distribution oscillator circuit
