Bias and degaussing oscillation circuit of monophonic recorder
Source: InternetPublisher:三月小雨 Keywords: Mono recorder oscillator circuit BSP Updated: 2020/06/13
Shown is the bias magnetization and degaussing oscillation circuit of the tape recorder , which is mainly composed of transistor VT1 and an oscillation transformer.
The primary winding of the oscillation transformer T and C1 form a resonant circuit. The resonant circuit is connected between the base and collector of transistor VTI and serves as
a load for the collector of vri. C2 is the coupling capacitor. &, C4 constitutes a filter circuit, and the power supply +B voltage is added to the primary center tap of the transformer through R4
to provide DC bias to the base of the transistor VT1 through the winding.
The secondary output of the oscillation transformer oscillates the signal. Provides bias magnetic signals for the recording heads and provides silencing signals for the silencing heads. Selecting
the value of C6 can change the size of the recording bias. to achieve the optimal magnetic bias amplitude.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Analysis of the basic principle of measuring resistance by bridge method
- The Importance and Ideal Model of Impedance Matching
- What are the classifications of filters?
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Causes of PCB deformation How to prevent circuit board bending and warping
- Important things to know about PCB routing and how to design the right routing for your PCB
- How to build a triangle wave generator using an op amp and discrete components
- What is the difference between high-side and low-side resistive current sensing
- Smoking Cessation Circuit
- Agricultural temperature control circuit
- Agricultural small tractor lighting circuit
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Proportional frequency discriminator circuit
- Diode balanced amplitude modulation circuit
- Guest arrival signal recognition circuit
- Sawtooth wave generator circuit (1)
- Sine wave signal generator circuit
