DC output DC converter circuit
Source: InternetPublisher:黄土马家 Keywords: converter DC conversion Updated: 2021/08/23
A DC converter circuit that takes a single DC input and converts it into multiple parallel DC outputs .
![DC output DC<strong>converter</strong> circuit](http://www.eeworld.com.cn/circuit/upload/e5a440983ddc8f8c24b2e77268b829e3/c90d6cc2325db472f593b3f310c1b54d.jpg)
Circuit description
This circuit uses a single DC input (nominally 12 volts) and converts it to four simultaneous output voltages of 9, 6, 5 and 1.5 volts. Common 78xx series voltage regulators provide output voltage control, providing 9, 6 and 5 Vdc outputs. The 1.5 volt power supply is derived using an LM317 voltage regulator. In order to reduce the electrical energy and thermal energy output from the 5 volt regulator the LM317 is fed. Calculation of the output of LM317: VO = 1.25 (1 + R1/R2) and R1 200 ohms (using 180 plus 22 ohms in series) This project is 1.5 volts. F2, 3,4,5 output fuse, at 500 mA (0.5). If the input power is full 500 mA then the DC input must be able to source at least 2 amps from each output . 1 lit LED shows the circuit is operating.
- Analysis of the working principle of switching regulator
- The basic principles of power supply design. What are the key components of a power supply?
- Benefits of Wide Bandgap Technology for Power Converters
- Using Lead-acid Battery as Power Source for Walkman
- Charging control circuit made by solar energy
- LM317 regulated power supply
- 0.7~24V continuously adjustable current limiting power supply
- Constant current charger using light emitting diode as voltage regulator
- Design of electric vehicle charger
- Homemade home inverter circuit diagram
- Power circuit b composed of intelligent thyristor modules
- Portable device charging power circuit design
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Super Class A power amplifier power circuit
- audio power circuit
- Single LTC power circuit
- led drive power circuit
- ±15V active servo power circuit
- Common power circuits and applications 07
- COMPAQ 420G type SVGA color display power supply circuit
