Using Lead-acid Battery as Power Source for Walkman
Source: InternetPublisher:spectrum Keywords: Power supply lead-acid battery Updated: 2024/11/12
The dry lead-acid battery has an output voltage of 6V and a capacity of 0.5Ah. In terms of its size and capacity, it is very suitable for powering a tape player. Since most tape players are powered by two AA batteries, a step-down DC-DC converter as shown in the attached figure needs to be connected between the battery and the player.
The converter has an input voltage of 33V to 16.5V, an output voltage of 3.3V, and a maximum output current of 3A. When the output current is 1A, the conversion efficiency is over 94%, and the static power consumption of the device is only 80μA.
T1 uses a 5A, 60V MOSFET; D1 uses a 3A Schottky diode; L1 uses a magnetic core inductor that can pass SA current, which requires the wire diameter of the inductor to be thick enough, and it is best to use multiple strands of wire. Other components are selected as indicated in the figure.
It is necessary to explain the role of resistor R1. This resistor is crucial to suppress the output ripple of this converter: if the peak current flowing through T1 is too large, the signal is input through pin 6 of IC1, and IC1 turns off T1, which effectively suppresses the peak current and reduces EMI.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- A simple positive and negative power supply circuit
- An ultra-low output voltage regulator
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- Design of electric vehicle charger
- Production of backup power supply for cordless phone
- Homemade Electric Bike Fast Charger
- What is the purpose of connecting a capacitor between the DC power supply and ground?
- One article to understand the intermediate bus structure
- Summary of key points of switching power supply PCB layout, worth collecting!
- Why is the scrapped volume of electric vehicle batteries so much higher than predicted?
- Possible factors why laptop power adapter is not universal
- Automatic reset timer circuit
- Polarity conversion power supply (ICL7660) that only needs 2 external capacitors to operate
- Medical infusion alarm circuit
- Single-ended input circuit (5V power supply)
- Set-base coupled monostable circuit
