Tachometer circuit
Source: InternetPublisher:Lemontree Keywords: BSP phototransistor potential Updated: 2020/05/15
Use a meter to measure the speed of the electric fan, and place the fan blades between the light source (bulb HI.) and the photosensitive transistor . When the light is blocked by the blades,
the light cannot shine on the phototransistor, and the VTI) is in a high-resistance state; after the blades turn a certain angle, the light shines on the VTL from the gap between the blades, and
the phototransistor is turned on and in a low-resistance state. .
When the fan blades rotate continuously, the phototransistor is intermittently illuminated three times during each revolution (a typical table fan only has three blades). Since a 12V voltage is applied
to both ends of the series circuit of the resistor RJ and the photosensitive transistor , a pulse potential
will
be formed on the two poles of the VTL with the intermittent irradiation of light . After
the pulse potential is differentiated by the differential circuit composed of the input resistor of Nan C and VT , a series of sharp pulses are formed, and then
rectified by VD1 and VD2 to obtain a pulse signal with twice the frequency, which is output through the capacitor c2 and sent to the microammeter. Head PA, the rotation speed is indicated by the pointer of PA. The higher the rotation speed
, the greater the pointer deflection, and vice versa.
If you have a digital frequency meter, there is no need to use a PA. Connect the lead between point A and ground, and directly connect it to the input terminal of the digital frequency meter to
display the speed number.
- How to test whether the multimeter is working properly
- Multimeter with small capacitor test circuit
- Design of wireless meter reading system based on DSP
- NE555 makes a simple and practical acupoint detector
- TC02 temperature measurement circuit
- Design of Multi-point Temperature Measurement System Based on DS18B20
- A simple electronic muscle stimulator circuit
- Production of acoustic and optical digital level detector
- Application of TDA1514
- direct coupled amplifier circuit
- Agricultural temperature control circuit
- Rural vegetable greenhouse lighting circuit
- Biogas concentration detection line
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Junction field effect transistor mixer circuit
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Wireless microphone circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
