Electrical schematic diagram of DC voltmeter input at non-inverting terminal
Source: InternetPublisher:风向双子座 Keywords: Voltmeter DC voltage BSP Updated: 2020/03/23
The non-inverting terminal inputs A, and the electrical schematic diagram of a DC voltmeter composed of a milliamp meter is shown in the figure.
In the figure, the operational amplifier uses LM324.
In order to reduce the impact of the meter parameters on the measurement accuracy, the meter is placed in
the feedback loop of the operational amplifier, and the range can be switched by simply changing a resistor
. After the resistance is determined, the ammeter can be calibrated directly with the voltage value.
It should be noted that the circuit in the figure is suitable for measuring
related circuits that share a common ground with the operational amplifier circuit. In addition, when the measured voltage is high,
an attenuator should be set at the input end of the op amp.
- Circuit principle and production of six-tube radio
- Making an FM receiver with a high-frequency head
- FM microphone made by 9018
- Superheterodyne receiving module circuit using RX3310A
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- U3742BM ASK/FSK 433.92/315 MHz Receiver
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- Common RF receiving circuit design for toys (3 high-frequency parts)
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Inpatient pager circuit
- High-efficiency speaker circuit for rural stage
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- base amplitude modulation circuit
- Broadband high frequency power amplifier circuit
- color discrimination circuit
- Color display circuit
- Sawtooth wave generator circuit (2)
- Sine wave signal generator circuit
