Concentration meter circuit
Source: InternetPublisher:spectrum Keywords: BSP LED photoresistor Updated: 2020/01/16
The photoresistor concentration meter is used to detect the light energy passing through the substance to
understand the composition or properties of the substance. First, the transmittance intensity of the standard solution must be measured, so that
the concentration of the solution to be measured is known. The circuit is shown in Figure 5-35.
This kind of concentration meter requires monochromatic light, so the light-emitting diode VI is used. as
a light source.
VT1, VT2, etc. form a differential circuit . When the LED does not light up and there is no light source irradiating the photoresistors
RL1 and RL2, adjust the potentiometer RP so that the mA
meter indicates 0, then the zero calibration is completed. At this time, turn on the power of the light-emitting diode smart LED . Through the light source's illumination of the standard solution and the liquid to be measured,
the concentration of the liquid to be measured can be indicated
on the milliamp meter .
Divide milliamperes into concentration grids according to relevant standards, so that
the concentration value can be easily read.
- Bat sound detection circuit
- Simple electric tachometer
- Level measurement circuit composed of AD737
- Using NE555 to make diode and triode detector
- Leakage Tester
- LM3914 makes car battery detector
- Making an Induction Electroscope Using CD4069
- Simple and easy to make zero degree detector
- Simple password electric lock
- Light Detection 4 to 20mA Current Transmitter Circuit
- stuttering correction circuit
- Electric massager circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Farmland drainage automatic control circuit
- AC voltmeter
- Amplitude modulation circuit composed of MC1496
- Three primary color display circuit
- Motorcycle flash light circuit
