A simple and low-cost light alarm circuit sharing
Source: InternetPublisher:spectrum Keywords: Alarm circuit ic555 LDR Updated: 2024/06/03
This is a simple and low cost light alarm circuit using timer IC555 as a sound generator and LDR to sense the ambient light. This alarm gets activated when the light beam on the LDR photocell is interrupted (You can use the light from a flashlight which will give you a power source to keep it on, this could be 3 volts either AC or DC).
Components List:
capacitance:
C1:0.1uF
resistance:
R1: 100K (potentiometer)
R2: 1K
R3:47K
R4:100K
R5: 27 ohm
R6: 220 ohm
semiconductor:
IC1:555
TR1: 2N3055, C1060 or C1226
D1:1N4002
other:
Speaker 8 or 16 ohms
1LDR/Phototube
When the LDR/phototube receives light, the resistance is low, thus blocking the positive voltage supplied by R4 to IC555 terminal 4, keeping the multivibrator off and the speaker silent. When the phototube stops receiving light, its resistance increases within a fraction of a second, causing it to reach the positive voltage at the above terminal, activating the alarm.
Circuit Note: The LDR should not receive any light other than that used for activation.
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Perform surgery on the speaker protection circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Simple three-phase motor phase loss protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Delay switch made with LM431
- Car audio system anti-theft circuit
- Simple disconnection burglar alarm
- Call for help alarm circuit
- Verbal reversing alarm circuit (2)
- Overflow alarm circuit
- Household harmful gas alarm circuit
- Household gas alarm circuit composed of gas sensor
- Centralized control of the rescue alarm circuit
- Gas-sensitive alarm circuit three
- Water full alarm circuit three
- Water full alarm circuit 2
- One of the three-phase AC power neutral line open circuit alarm circuits
