One use and one standby constant pressure water supply frequency conversion speed control circuit b
Source: InternetPublisher:同住地球村 Keywords: Control circuit constant pressure water supply frequency conversion speed control Updated: 2021/11/30
The soft start control circuit of the fire pump (one in use and one in standby) using FSR1000X soft starter is shown in Figure 5-26. When the transfer
switch 1SA is placed in the automatic position, one of the two fire pumps is running and the other is in standby. The two pumps are standby for each other
. After an operation failure, the standby pump is automatically put into operation immediately. When 1SA is placed in the manual position, both pumps can be operated manually and independently. The time relay
(KT) delay setting value is greater than the soft start time of a single unit.
In the figure, 1 and 2 are bypass relay terminals ; 3 and 4 are fault output terminals; 7 is instantaneous stop input terminal; 8 is soft stop
input terminal; 9 is soft start input terminal; 10 is common contact input terminal (COM ); Il is the ground terminal (PE);
12 and 13 are the control power input terminals .
- Audio Adapter Cable - Upgrading Car Audio with MP3 Player
- Smart Farm Design Solution Based on LoRa
- Battery equalization system and control method thereof
- JC3.5 hydraulic controller and its wiring a
- Electronic mousetrap circuit
- Catillac luggage compartment opening circuit diagram
- GW-0520CH-PS switching power supply circuit diagram
- Electronically controlled fuel injector test circuit
- Electronic ventriloquist circuit
- Simple temperature control circuit diagram
- 13 examples of electric drag control circuit diagram
- fire smoke control circuit
- Ringtone control circuit
- time control circuit
- Electromagnet control circuit
- Automatic tuning control circuit
- Relay control circuitb
- Humidity detection box control circuit in greenhouse
- Small power electric heater temperature detection control circuit
- SHD301 single water supply pump frequency conversion speed regulation constant pressure water supply circuit b
