Small power electric heater temperature detection control circuit
Source: InternetPublisher:sigma Keywords: Control circuit temperature detection low power BSP Updated: 2020/02/11
Shown is a simple low-power electric heater temperature detection control circuit, which is mainly
composed of a power supply circuit and a temperature detection control circuit.
The power supply circuit is mainly composed of capacitor Cl, resistor Ri, rectifier diodes VD1, VD2, filter capacitor C2 and Zener diode
vs. The temperature detection control circuit is mainly composed of thermistor RT and potentiometer RP. , voltage stabilizing integrated circuit IC, electric heater
and peripheral related components. The output DC voltage of the power supply circuit is divided into two channels: one channel is used as the input DC voltage of the IC; the other channel
provides control voltage for the IC after
being divided by RT, R3 and RP .
When the ambient temperature is low, the resistance value of RT is large, and the partial voltage of the control terminal of LC is high, causing rC to conduct, diode VD3 lights up, VT
is triggered and conducts, and the electric heater starts to heat up when the temperature rises. After reaching a certain temperature, the resistance value of RT decreases as the temperature increases,
causing the voltage at the control terminal of the integrated circuit to decrease. VD3 goes out, VT is turned off, and EH is powered off to stop heating.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- The Importance and Ideal Model of Impedance Matching
- Datasheet/Pinout/Technical Specifications of LMC555
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- DIY a decorative lamp
- Analysis of three simple electronic dice circuits
- Structural diagram and function of sliding resistor
- What is a Demultiplexer
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Analysis of rectifier circuit types and principles
- stuttering correction circuit
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Fish pond oxygenation reminder circuit
- Egg heating control circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Fault signal trip circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (1)
