LM5007 application circuit diagram
Source: InternetPublisher:宋元浩 Keywords: Voltage Regulator LM5007 Updated: 2024/07/17
The LM5007 is an integrated step-down switching regulator that has all the necessary systems required to make a cost-effective and reliable switching regulator circuit. The IC is available in MSOP-8, LLp-8 packages and has many built-in features such as thermal shutdown, undervoltage lockout, duty cycle limiting, current limiting, etc.
The output voltage of this regulator can be adjusted using resistors R3 and R4. For the given values of R3 and R4 in the circuit diagram, the output voltage will be 10V. The formula for controlling the output voltage is Vout = 2.5x (R3 + R4) / R4. Resistor R1 sets the switch on time and C4 is the boost bootstrap capacitor. Resistor R2 determines the change in the off time and C3 is the decoupling capacitor.
LM5007 pin diagram
LM5007 Typical Application Schematic Diagram
LM5007 application circuit diagram (I)
The supply voltage can be anywhere between 12 and 72 VDC.
The output voltage can be adjusted using R3 and R4.
C1 and C5 are polyester capacitors.
C1 and C2 must be rated for at least 100V.
R5 and C5 form a filter network.
The output current limit of LM5007 is 700mA.
LM5007 application circuit diagram (II)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Build a simple buck-boost regulator and test it on a breadboard
- Benefits of Wide Bandgap Technology for Power Converters
- In-depth analysis of DC-AC converter inverter
- Energy-saving motorcycle rectifier regulator
- Isolated two-wire current loop circuit (XTR101, ISO100)
- 3~15V 10A adjustable voltage regulated power supply
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Power circuit with smoothing filter capacitor
- Single phase thyristor slotless nickel plated power circuit
- Recording level power supply circuit
- Karaoke light controller circuit (1)
- Household emergency power circuit
- Head amplifier dedicated power supply circuit
- Telephone power circuit
- 5V uninterruptible power supply circuit
- ±5V, ±12V power circuit A
- Small power UPS power circuit and production
