Control circuit of three-phase wound rotor asynchronous motor
Source: InternetPublisher:闪电杰克 Keywords: Asynchronous motor control circuit winding BSP Updated: 2021/12/19
A time relay is used to control the opening and closing of the noon resistor.
The action process of this circuit is:
(1) Close Qs and connect SB1. The results are as follows:
The KM1 coil is energized, the contacts (1-3) are closed and self-locking;
When the KM1 coil is energized, the KM1 contact is closed and the motor M starts to start
(Shu and Ma Shen people);
KMl (1-5) The contacts are closed and the KT1 coil is energized - KTl (1-7)
The contacts are delayed and closed .
(2) KM2 coil is energized - KT2 main contact is closed and is short-circuited (cut
off) for a day.
KM2 (1-9) Contact is closed - KT2 coil is energized - KT2 (1-11)
contact is delayed closed.
(3) The KM3 coil is energized, the KM3 main contact is closed, the KM3 main contact is short-circuited
(cut off), and the starting process ends.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- The meaning and importance of circuit protection, common types of circuit protection
- Model rocket launch controller circuit
- Tutorial on making your own remote-controlled robotic arm
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Perform surgery on the speaker protection circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of the principle of automatic power-off switch during power outage
- Guanghua brand anti-theft doorbell electronic lock circuit
- Set timing circuit when power is on
- Pulse therapy circuit
- Homemade disinfectant circuit
- Particle clogging alarm circuit of wheat seeder
- Farmland drainage automatic control circuit
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Parallel crystal oscillator
- Double gate field effect transistor high frequency amplifier circuit
- Second-order active band-stop filter circuit
