Double gate field effect transistor high frequency amplifier circuit
Source: InternetPublisher:公子李 Keywords: High frequency amplifier amplifier circuit field effect transistor BSP Updated: 2020/10/06
Double-gate field effect transistors are also called double-gate MOS transistors. One tube has two control gates. From a structural point of view, it can be considered to be
composed of two single-gate field effect transistors connected in series. From a characteristic point of view, since the second gate G2 has
a certain shielding effect, the feedback capacitance between the drain and the first gate becomes Very small.
Figure 21-17 shows a
dual-gate field effect transistor high-frequency amplifier with automatic gain control in a color TV high-frequency tuner .
The reference values of component parameters are as follows:
1) Transistor: VT is a double-gate CMOS tube.
- Share the features of Wi-Fi 6 that you don’t know
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- DIY a network router
- TA8164P FM Radio
- RXM-433/418/315-LC-S Series Receiver Modules
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- rfRXD0920 ASK/FSK/FM 930~800 MHz Receiver
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- DKIOOOT OOK 315 MHz Transmitter Module
- AT86RF211 FSK 950~400 MHz transceiver
- Rice mill circuit
- Particle clogging alarm circuit of wheat seeder
- Diode Balanced Mixer Circuit
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- Diode square rate detection circuit
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Guest arrival signal recognition circuit
- Home appliance repair signal generator circuit
