Reverse braking control circuit
Source: InternetPublisher:酷到被通缉 Keywords: Brake control circuit BSP power supply contacts Updated: 2021/09/10
Reverse braking is to reverse any two of the power lines connected to the motor when it is stopped. Due to the change in the phase sequence
of the power supply
, an electromagnetic torque in the opposite direction to the original direction will be generated. The motor still
rotating in the original direction acts as a brake. When the motor speed
approaches zero, the power supply is disconnected. This method has large braking torque and fast braking
, but the braking current is very large. Generally, a resistor must be inserted in series with the stator circuit. The asynchronous motor can perform
reverse braking
after changing its power
phase sequence. When the phase sequence is changed, the rotating magnetic field of the motor stator is reversed,
producing a reverse torque opposite to the original torque of the motor, thus acting as a brake
The reverse braking circuit of asynchronous motor is shown in Figure 4-23. When button SB1 is pressed
, contactor KM1 is closed, causing the motor to drive speed relay
SR - to rotate. After the speed reaches the rated speed, the SR moving contact is closed
and the brake is ready. After pressing the SB2 stop button, Klffl is powered off and
its contact is broken. The SR contact is still
closed under the action of motor inertia. At this time, KM2 is closed and the motor is reversely connected. When the motor speed drops until it stops
, SR is turned off. KM2 is released and braking is completed.
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Perform surgery on the speaker protection circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Motor automatic cycle control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of a four-bit remote control component capable of remote reset
- Infrared blocking alarm device
- Infrared detection alarm
- Water supply reminder after water outage
- Homemade disinfectant circuit
- Farmland irrigation automatic control circuit b
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Broadband high frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
