Three-phase asynchronous motor continuous control circuit
Source: InternetPublisher:偷熊计划 Keywords: Control circuit three-phase asynchronous motor BSP Updated: 2021/03/23
The three-phase asynchronous motor continuous operation control circuit is shown in Figure 4-2.
Compared , three additional links are added: First, the auxiliary
moving contact KM of the contactor KM is connected
in parallel with the start button SB2. The function is to press the start button SB2, the contactor KM is energized, the motor M
starts and runs, and the KM auxiliary moving contact
in parallel
with SB2 is also closed. When the start button SB2 is released, KM still causes the contactor KM coil to continue When energized, the motor M continues to run continuously.
This effect is called "self-locking". The KM contact is called "self-locking". The second contact is to control
the motor to stop. A stop button SB1 is added. Press the stop button SB1. Cut off the control circuit, the main contact
of the contactor KM shoe L is disconnected, and the motor stops; thirdly, a thermal relay FR is added. When
the motor is overloaded and heats up, after a period of time, its moving contact is disconnected, the control circuit is cut off , and the contact The main contact of the device
KM is disconnected and the motor stops.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design of an autonomous plant watering system using ATtiny85
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and manufacture of three-phase motor protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Home wireless burglar alarm circuit
- Password type motorcycle anti-theft device
- "Watchdog" anti-theft alarm circuit
- electromagnetic field sensor
- stuttering correction circuit
- Inpatient pager circuit
- Homemade disinfectant circuit
- Crop anti-frost circuit
- Agricultural small tractor lighting circuit
- collector amplitude modulation circuit
- ring amplitude modulation circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (1)
