Crop anti-frost circuit
Source: InternetPublisher:桂花蒸 Keywords: BSP routing alarm circuit Updated: 2021/03/21
The frost alarm introduced in this example can send out an audible alarm signal when the ambient temperature is lower than 1°C to remind farmers to prepare for frost in time.
(1) Circuit composition The frost alarm circuit consists of a power supply circuit, a temperature
detection control circuit and an alarm circuit , as shown in Figure 8-19. The power circuit
consists
of battery GB, power switch S and electric hot spot thermometer Q.
The alarm circuit is composed of a sound integrated circuit IC, a resistor, a resistor, a transistor
VT and a speaker Y.
(2) Circuit principle: After turning on the power switch S, the alarm circuit enters
the alert state. When the ambient temperature is higher than 1°C, the electric heating control contact of Q is in
a disconnected state, the alarm circuit does not work, and Y does not sound. When the ambient temperature
drops to 1°C, the electrothermal control contact of Q is turned on, causing ]C to be triggered to work.
The audio signal output by the ◎ pin of LC is amplified by VT, and drives Y to sound an alarm.
- Detailed explanation of the working principle of the parking light circuit
- How to Build a Smart Knock Detection Door Lock Using Arduino
- How to design a health emergency alert device using MPU6050
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- Disconnected anti-theft alarm circuit (1)
- Water dispenser double sheet control circuit
- Electronically controlled fuel injector test circuit
- Two-channel SL320 level indication circuit
- Toy police car circuit
- Analog counter circuit circuit diagram
- Egg warming circuit
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- Wien bridge oscillator circuit
- Broadband high frequency power amplifier circuit
- OTL low frequency power amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
