DIY an indoor and outdoor webcam
Source: InternetPublisher:念念Brown Keywords: DIY design webcam Updated: 2024/12/17
Have you ever wanted to add a little more security to your neighborhood but didn't want to buy an expensive 1080p webcam, or just wanted to make one yourself? Well, that's exactly what this article is about!
First, you will need the following parts:
Pi Camera
Pi Zero W
Cable adapter
Waterproof DC jack
5v 2A DC Power Supply
And the following tools:
iron
drill
screwdriver
Step 1: Download and Flash Rasbian Jessie Lite
Visit https://goo.gl/KJcV7F to download the zip file, then extract it to flash using win32 disk imager, found here: https://goo.gl/VgGrNm.
Step 2: SD Card
In the boot partition, the one you see on Windows, add a file called wpa_supplicant.conf and edit it in Notepad. Copy and paste the code below, then edit the SSID and password variables.
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid=“SSID” psk=“PASSWORD” }
Then add a blank ssh.txt file to enable ssh.
Step 3: Connect to the Pi via SSH
I used Fing to scan my network to find the Raspberry Pi, and then connected via SSH using Putty (https://goo.gl/d7nFtq).
Step 4: Setting up PiCam
This is easy: copy the following command into your terminal and it should now be able to run on its own.
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install git
git clone https://github.com/silvanmelchior/RPi_Cam_Web_Interface.git
cd RPi_Cam_Web_Interface 。/install.sh
Step 5: Setting up PiCam
The subfolder field is what you get the camera from (ex: 192.168.1.12/camera); this can be anything you want. Everything else is ready to go!
We’re not going to restart yet because we still need to open the camera, so select “No” when it asks.
Step 6: Open the camera
We are now going to turn on the camera. Run raspi-config:
sudo raspi-config
Then select Interface Options and then Camera. A message will pop up saying "Do you want to turn on your camera", select yes, then select yes again when asked to restart.
Step 7: Focus the camera
Adjust the lens until it's perfect and it should be in focus no matter the distance of the object. The live video feed has no lag so it's very easy.
Step 8: Assemble the box
Solder the wires as per the images I provided. I recommend checking the polarity of the DC jack before connecting, but 5v will usually go to the shorter pin and GND will usually go to the longer pin. Use hot glue to hold everything in place; make sure not to get any glue set in the connectors if you want to remove them later. I used some brackets to hold the camera in place. This is fairly effective, but remember they may not be very solid so you need to be a little gentle with them.
- How to use Tesseract for optical character recognition on Raspberry Pi
- How to Design an Automatic IoT Egg Incubator Using ESP8266
- DIY a simple weather station
- Design a BLE thermos cup using M5Stack
- How to make a clock Bluetooth IOT speaker using Arduino
- Automatic recovery electronic fuse with soft start function
- Electronic fly killer
- Bookcase moth-proofing circuit made with 7556 dual-time base circuit
- High power laser constant current drive circuit
- Detailed explanation of car battery charging circuit diagram
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
