How does an optocoupler work? Introduction to the working principle and function of optocoupler
Source: InternetPublisher:通通 Keywords: Optocoupler Updated: 2021/02/13
Optoelectronic products have gradually become indispensable equipment in our lives. It brings a lot of convenience to our lives, among which the optocoupler is a common front-light device. So how do optocouplers work?
1. Introduction to optocoupler
Optocoupler is mainly a photoelectric conversion component that revolves around light as a medium, which can realize free conversion between light to electricity and electricity to light. We can also call it an optoelectronic isolator. The reason why it is called so is mainly because the optocoupler can effectively isolate the electrical signals in the circuit. Effective protection circuit.
2. Working principle of optocoupler
Before we understand the working principle of the optocoupler, we first need to clearly understand the components of the optocoupler. It is mainly composed of two parts, namely the light source and the light receiver. Then the working principle revolves around these two parts.
The wiring port of the light source is the input terminal, and the current enters here. The connection port of the photoreceiver is used as the output terminal, and the current is output from here. When current enters the light-emitting source, the light-emitting element emits light due to the action of the current, and the brightness of the light changes depending on the input current. When light hits the photoreceptor, the photoreceptor reacts, and the current output from here becomes photocurrent.
3. The role of optocoupler
Optocouplers are mainly used in various circuits, which can adjust the current state and play a certain protective role in the circuit. According to its characteristics, people use photoelectric couplers to make controllable photoelectric switches , which can play a very good role in controlling and stabilizing switching circuits and high-voltage circuits, providing a lot of convenience for people's use.
The above is all the content shared today. If you want to know more about electronic components, you can continue to follow the editor!
- How to Build a Simple Yet Powerful MP3 Player
- Satellite TV Set Top Box Remote Controller
- Plastic sealing machine circuit diagram
- Electronic Rat Killer Circuit
- Ultrasonic dog chaser made by NE555
- Production of electric water bottle energy saver
- How to create image processing solutions using HLS capabilities
- How to build an internet-connected traffic meter
- A detection circuit with keen hearing
- Analysis of the circuit of DL-01 low-frequency electrotherapy instrument
- Optocoupler controlled oscillator circuit
- Photoelectric drive circuit
- Ringing signal detection circuit
- Delay circuit using photocoupler
- Interface circuit for automatic counting using electronic counter d
- Interface circuit for automatic counting with electronic counter a
- Long-distance ringtone detection circuit using photoelectric coupler
- Optocoupler MOC304 dimming control circuit diagram
- 4N22A to 4N24A type photocoupler circuit
