A simple AM transmitter circuit
Source: InternetPublisher:smallembedded Keywords: Transmitter transistor signal amplifier Updated: 2024/06/24
Below is the circuit for a simple AM transmitter. This circuit is available in kit form and will work just fine since the kit is commercially available.
The circuit uses a combination of transistors SA101 and SA103 as a modulation signal amplifier.
Medium wave (MW) is a part of the medium frequency (MF) radio band used primarily for AM radio broadcasting. For Europe, the MW band ranges from 526.5kHz to 1606.5kHz, while in North America, the extended MW broadcast band runs from 535kHz to 1705kHz.
The wavelengths in this band are long enough that the radio waves are not blocked by buildings and hills, and can travel along the curvature of the Earth beyond the horizon; this is called ground wave. Actual ground wave reception typically extends to 200-300 miles, with longer distances over terrain with higher ground conductivity and greatest distances over salt water. Most broadcast stations use ground wave to cover their listening areas.
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- How to Build a Simple FM Radio Receiver on a Breadboard
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- Pocket Wireless Microphone
- Design and Analysis of Half-duplex Intercom Circuit Using LM386
- DKl000R OOK 315 MHz Receiver Module
- RXM-433/418/315-LC-S Series Receiver Modules
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- RCV420 4~20mA Precision Current Loop Receiver
- Crystal controlled local oscillator circuit diagram
- Capacitive feedback oscillator circuit
- superheterodyne radio circuit
- Tire leak detector circuit
- Signal level status display circuit
- Lost child alarm circuit a
- Infrared remote control relay circuit b
- Infrared anti-theft alarm circuit 3a
- transmitter toy circuit
- FM transmitter circuit 07
