superheterodyne radio circuit
Source: InternetPublisher:supremeOne Keywords: Radio circuit BSP transistor IF signal Updated: 2020/09/02
The tuning loop is composed of a variable capacitor cI. , Cn and antenna coil L]. Adjust the variable capacitor G,. The natural frequency of the LC loop can be changed
to make it equal to the frequency of the radio station and generate resonance to select radio station signals of different frequencies. The antenna Lz is then coupled to the lower-level frequency conversion circuit for frequency conversion.
The frequency conversion circuit is composed of three parts: frequency mixing, local oscillation circuit and frequency selection circuit. The frequency conversion stage is centered on the transistor VT1, which has
both oscillation and mixing functions.
The transformer feedback oscillator
is composed of transistor VTl (3AG24), variable capacitor Cib. Cr2, oscillation transformer (referred to as medium oscillation or short oscillation) T2 and capacitors G and C3 .
It can produce high-frequency constant amplitude oscillation signals, because Ci. and Clh are components of double-connected variable capacitors. They rotate coaxially
to ensure that the oscillation frequency of the local machine is always 465kHz higher than the frequency of the input radio signal, and convert the input high-frequency signals of different frequencies into a fixed
465kHz intermediate frequency . Signal .
The intermediate frequency signal that is the difference between the input radio signal and the local oscillator signal is always a fixed value of 465kHz. It can flow unimpeded in the
intermediate frequency and be amplified step by step. A fixedly tuned intermediate frequency amplifier is used to The amplification performance of fixed-frequency intermediate frequency signals
is stable.
The main function of transistor VT3 is to detect waves.
Transistor VT4 forms a voltage amplification stage (push stage). Its main task is to amplify the audio signal so that the power amplifier stage can obtain a larger
audio signal voltage so that the radio has sufficient volume.
Transistors VT5 and VT6 form a Class B power amplification stage, which amplifies the audio signal to drive the speaker to produce sound. Superheterodyne
radio circuit such as
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- How to Build a Simple FM Radio Receiver on a Breadboard
- How to use FPGA and RS485 for industrial communication
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- AM Transmitter
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- Radio coding transmission circuit composed of MICRF102 and PT2262
- Eight-way remote control transmitter circuit using CS901
- RXM-433/418/315-LC-S Series Receiver Modules
- TX4930 FM/FSK 915/868/433 MHz Transmitter
- Self-defense anti-riot circuit
- stuttering correction circuit
- Electric massager circuit
- Inpatient pager circuit
- Homemade disinfectant circuit
- Physiotherapy ventilator circuit
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Color display circuit
- Home appliance repair signal generator circuit
