Circuit diagram of 18W audio amplifier
Source: InternetPublisher:明天见 Keywords: Audio amplifier power transistor Updated: 2024/01/04
This is the circuit diagram of the 18W audio amplifier. This circuit is very simple and cheap to build. It uses a pair of power transistors TIP41A and TIP42A for single-channel operation. The power supply used in this circuit is a bipolar (split) power supply, which is constructed using a center-tapped transformer.
18W audio amplifier circuit diagram
Parts List:
Power supply part:
18W audio amplifier circuit notes:
CD players, tuners and recorders can be connected directly.
Do not exceed 23+23V power supply.
Q3 and Q4 must be mounted on the heat sink.
D1 must be in thermal contact with Q1.
Quiescent current (best measured with an Avo meter in series with the Q3 transmitter) is not critical.
Adjust R3 to read between 20 and 30mA without an input signal.
Add R8 (optional) to facilitate current setup.
Proper grounding is important to eliminate hum and ground loops. Connect the ground terminals of J1, P1, C2, C3 and C4 at the same point. Connect C6 to output ground.
Then connect the input and output grounds of the power supply ground respectively.
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- 6N5P tube direct-coupled single-ended amplifier
- The production of 6P14 small tube amplifier
- Using 6P15 to create an ultra-linear push-pull amplifier
- Minimum output noise/reduced output power circuit using LM4910
- Volume synchronization circuit constructed with discrete components
- 2W×2 power amplifier circuit using LM1877
- Differential input audio amplifier circuit composed of LM4904
- Horseshoe gallbladder preamplifier circuit
- Low Power Single Supply Audio Amplifier
- Low power audio amplifier MC34119-05
- Low power audio amplifier MC34119-04
- Low power audio amplifier MC34119-01
- 8W audio amplifier integrated circuit
- 75 watt audio amplifier circuit diagram with load line protection
- Transmitter circuit with output from field effect power transistor
- Output uses DC coupled 15 to 60W audio amplifier circuit
- 35W audio amplifier circuit
- Audio amplifier circuit for record player
