Volume synchronization circuit constructed with discrete components
Source: InternetPublisher:spectrum Keywords: Synchronous circuit Updated: 2024/09/14
Many audio systems use a single potentiometer to adjust the volume of L and R channels synchronously, which is often achieved using a dedicated integrated circuit (such as LM1035), and some also use a coaxial potentiometer to adjust. Here we introduce a simplest synchronization circuit made of discrete components, which is very practical for occasions such as temporary replacement and amateur production, and will not feel noise.
The circuit is shown in the figure below. The resistance of field effect tubes Q1 and Q2 changes with the gate voltage. When the RP sliding arm moves upward, the gate potential increases, and the resistance between the source and drain decreases; when the RP sliding arm moves downward, the potential decreases and the resistance increases, thereby attenuating the input signal to varying degrees to achieve the purpose of volume adjustment. Similarly, for more channels, just connect a few more field effect tubes (as shown in the dotted box). The oCI has a buffering effect on the adjustment, making the adjustment feel soft.
- TDA2009A power amplifier circuit
- Make the most beautiful sound with the least money
- Two unique tube preamplifiers
- Design and production of class AB headphone amplifier
- The fun of making ISD1820 voice recording box
- Design and production of NE5532+TDA1521 amplifier
- Installation of electron tube differential amplifier circuit
- Using Shuguang 350C tube to make tube amplifier
- LMl876 is used to assist the audio power amplifier circuit
- Active power amplifier circuit composed of TDA2003
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
