Circuit diagram of current output multiplier designed for voltage regulator ICLM78xx
Source: InternetPublisher:消失的歌 Keywords: Multiplier circuit Updated: 2023/12/25
This is the circuit diagram of the current output multiplier designed for the voltage regulator ICLM78xx. By default, the ID78xx series of voltage regulators will provide a maximum current output of 1A–1.5A. To increase the current output of this regulator, you may consider building this circuit. The circuit is simple, easy to build, and inexpensive.
Parts List:
R1, R2=4.7K
C1, C2=4700uF/16V
C3=47,000uF/35V
D1, D2, D3=1N5401 (3 Amp diode)
D4 and D5 – Light Emitting Diodes (LEDs)**
IC1, IC2–78xx series voltage regulator ICs (7805 for 5V, 7812 for 12V, etc.)
- Sharing layout and tips for multi-rail power supply design
- 5 Converter Topologies for Integrated Solar and Storage Systems
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Switching power supply circuit composition and function introduction of each part
- Principles and precautions of active discharge circuit
- Low cost and high performance LED constant current power supply
- A novel and practical DC low voltage stabilized power supply
- Mc34063 MP3 Switching Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- 24V power supply pure flat display high voltage power supply circuit diagram
- Single phase thyristor slotless nickel plated power circuit
- One of the transistor stabilized current power supply circuits
- Low voltage adjustable reference power circuit
- Power circuit for home appliance repair
- Common power circuits and applications 09
- Common power circuits and applications 03
- 5V uninterruptible power supply circuit
- ±5V, ±12V power circuit A
- CTX-C2 dual-band high-resolution color display power circuit
