Boost circuit based on EL7516
Source: InternetPublisher:宋元浩 Keywords: Boost circuit output voltage BSP Updated: 2020/09/13
![<strong>Boost<strong>Circuit</strong></strong> based on EL7516](http://www.eeworld.com.cn/circuit/upload/1034052af2b4a6ebf3b3f51c86440a97/f93302b43c8fdfabbb5af29688a6400b.jpg)
EL7516 is a boost chip that operates in 1.2MHz fixed frequency PWM mode and has a built-in 1.5A, 200mΩ MOSFET. In the electrical circuit, through DC/DC boosting effect, EL7516 converts the 2.7~5.5V input voltage into a constant output voltage of 12V . Like general PWM control chips, its FB pin sets the output voltage by selecting the resistance values of R1 and R2 . It is very simple to change the constant voltage circuit of the EL7516 into a constant current circuit that drives white LEDs.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- What kind of circuit is a voltage regulator circuit?
- Op amp power supply decoupling bypass measures
- Transformerless AC-DC constant current LED driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Charging control circuit made by solar energy
- Car power 1.5V-12V six-speed converter
- Constant current charger using light emitting diode as voltage regulator
- Mc34063 MP3 Switching Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Electronic thermometer circuit
- Particle clogging alarm circuit of wheat seeder
- Frequency modulator composed of NE566
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Motorcycle flash light circuit
- Various signal generator circuits
- Sawtooth wave generator circuit (1)
