Electronic thermometer circuit
Source: InternetPublisher:小胖友 Keywords: BSP Updated: 2020/03/08
The electronic thermometer circuit is as shown. RT is the thermistor and A is the integrated operational amplifier. VD1 ~ VD4 form a standard flow
path and output a one-way signal .
VT1, VT2, etc. form a switching
circuit . When the resistance of the thermistor RT
changes to a certain resistance value
with the temperature of the object being measured ,
a difference signal is output at points A and B.
This signal is amplified by A,
rectified by VD1~VD4, and then
added to the base of VT1. pole, VT1 is
on, VT2 is off, and the small light bulb
is on. Not lit}At this time. Change
the resistance of potentiometer RP2 so that
there is no difference signal output between points A and B,
then VT1 will be cut off, VT2 will be turned on, and the small light bulb will light up. If the potentiometer is marked with a temperature scale, then when the light is on, read
the temperature of the object being measured.
Rr is a metal shell thermistor with a negative temperature coefficient. The model is RRG3J22. The resistance value is lOkfl at 20°C. It is more ideal to use a glass shell
(a thermistor with a positive temperature coefficient can also be used). A uses the gain operational amplifier in the processing product. The leakage current of VT1 and VT2 should be less than
lOOtjLA, and Lu should be greater than 30. Small light bulbs use voltages below 2.5V. Ei uses ZZ. 5v instrument with laminated battery, Bureau Yi uses one AA
battery.
- Video doorbell design based on Raspberry Pi
- Grain temperature measuring instrument circuit
- Computer host overheating alarm circuit
- Catillac luggage compartment opening circuit diagram
- Electronically controlled fuel injector test circuit
- One of the cooling fan automatic control circuits
- Two-channel SL320 level indication circuit
- stapler main circuit
- Electronic ventriloquist circuit
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Motor overcurrent protection circuit
- strain sensor
- Ultrasonic blind pathfinder circuit
- Farmland drainage automatic control circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- base amplitude modulation circuit
- Schiller oscillator circuit
- Sawtooth wave generator circuit (1)
- Sine wave signal generator circuit
