High-loudness piezoelectric alarm buzzer
Source: InternetPublisher:CGDyW5Z7 Keywords: Piezoelectric alarm buzzer Updated: 2025/11/18
This is yet another truly remarkable buzzer circuit. It slightly sweeps the drive frequency to produce a very annoying sound. It uses a transformer to amplify the drive voltage on the piezoelectric device to over 200 volts peak-to-peak. It emits a deafening 120 decibels when measured at 12 inches.
- Stepper motor controller connection diagram
- Temperature-controlled fan
- Timed chicken coop door opener
- Voice-activated switch
- Dual Fan Controller
- Switch with locking relay
- Basic stepper motor control circuit
- Easy to make light controlled delayed flash toy car
- Make the phone play music
- Wind generator charging control circuit composed of LT1173
- Overload protection circuit for high-voltage motors
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Circuit diagram for AC voltage levels
- NJU7663 constitutes multiple negative voltage circuit diagram
- Triac voltage doubler power supply circuit
- Using AD586 to generate - 5.000V voltage circuit diagram
- Use high-pass filter to remove bias voltage circuit diagram
- Piezoelectric pump drive circuit diagram
- 10V reference voltage circuit with extremely low temperature coefficient
- Current type low voltage electric shock safety device circuit diagram
京公网安备 11010802033920号
