Improved dynamic expansion circuit
Source: InternetPublisher:三月小雨 Keywords: BSP extender Updated: 2020/09/11
It is a dynamic expander circuit with better performance composed of NE571 and LM 1894N . A variable bandpass filter composed of LM1894N is added to the dynamic expander
circuit. The reason is that ideal dynamic expansion requires the use of
an "RMS rectifier" to prevent the so-called "noise modulation breathing effect", and the "RMS The production cost of "rectifier" is very high and cannot be generally accepted. By adding a variable band-pass filter composed of LM 18ic)4N
before the expander ,
the impact of "wheezing noise" on the sense of hearing can be eliminated.
The signal after band processing by the noise reduction stage is input into the dynamic
expansion amplifier composed of N]ester 71 and NE5532N through c9. Since the conversion rate of the operational amplifier inside NE571 is only 0.SV/pLS, and its passband
is only effective in kilohertz, NE5532N is selected as its operational amplifier unit, leaving the operational amplifier unit in the original IC unused
(see figure The 5-11(a》o circuit uses only the two
unit circuits necessary for dynamic expansion, the variable gain unit and the average rectifier of the NE571, and the additional NE5532N forms a complete, high-performance dynamic expansion circuit.
This circuit The circuit 's adjustment of the expansion ratio is achieved by connecting resistor R4 in parallel between pins 5 and 3 of NE571. Through
experiments, using the value 100k as shown in the figure, a real and natural sound reproduction effect can be achieved. C12 is a built-in function of NE571 The filter capacitor of the rectifier
. Its value and quality have a great influence on the overshoot, rise speed and delay amount
of the expander . It is advisable to choose tantalum electrolytic capacitors with stable charge and discharge. At the same time, the l and 16 of the left and right channels The feet should be used in parallel.
- Make the most beautiful sound with the least money
- LM4766 Dual 40W+40W Power Amplifier
- The fun of making ISD1820 voice recording box
- The production of 6P14 small tube amplifier
- A simple and practical tube amplifier
- Stereo tube power amplifier
- LM4903/4905 high gain audio amplifier circuit
- Bridge output audio power amplifier circuit composed of LM1876
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- 2W×2 power amplifier circuit using LM1877
- Rural fish farming control circuit
- Greenhouse temperature control circuit
- Egg heating control circuit
- Domestic KD8041 integrated phase locked loop
- Varactor Diode Frequency Modulator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
- Motorcycle flash light circuit
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (1)
