TA7666,67 internal circuit and application circuit
Source: InternetPublisher:傻阿乐 Keywords: Application circuits light emitting diodes amplifiers transistors Updated: 2020/11/01
It is a dual-channel five-segment display circuit composed of TA7666 (TA7667) and its internal circuit schematic diagram. The circuit
uses a power supply voltage range of 6 to 12V. The input signal is input from the inverting input terminals of the two amplifiers
. The gain of the amplifier can
be adjusted by external resistors RF and Rs. The output terminal of the input amplifier is connected to an NPN transistor and is connected as an emitter
output, so the output terminal has rectifying and filtering functions after being connected to an external capacitor. There is a voltage stabilizing circuit inside the IC
to provide reference levels for comparators at all levels. The five voltage comparators of each channel are also connected with a transistor at the output end to form an
open-collector output, which is used to drive a five-digit LED display. The resistor in series with the LED is a current-limiting resistor, which can be
adjusted according to the characteristics of the LED . determine the current.
- Tutorial on making a MIDI arpeggio synthesizer
- Make a high-quality DAC board
- 75W audio power amplifier made with TMOS150
- Making a Simple Tube FM Radio
- Electronic toy dog
- Using 6P15 to create an ultra-linear push-pull amplifier
- Auxiliary audio power amplifier circuit using LM4730/LM4731
- High gain audio amplifier circuit composed of LM4818
- LM4902 differential input audio amplifier circuit
- LM4906 Audio Power Amplifier Circuit
- Current Detection Circuit Design Tips
- Six common constant current source circuit diagrams and analysis
- H-bridge drive circuit schematic diagram and enable control and direction logic
- 3V-5V level conversion circuit diagram
- Improved multivibrator circuit a
- Transistor reference basic bias circuit-voltage negative feedback type
- Interface circuit between power supply coupler and transistor a
- Fuse blown sound and light alarm circuit 4
- Ship navigation signal light circuit
- Cotton humidity detection circuit
