Six common constant current source circuit diagrams and analysis
Source: InternetPublisher:石榴姐 Keywords: Transistor analog circuit constant current source circuit diagram Updated: 2020/06/11
Comparing several V/I circuits, any unidirectional device without a triode can achieve AC constant current. After adding a triode, it can only achieve unidirectional DC constant current. Of course, the output current can be expanded with a power amplifier.
The fourth and fifth types are based on the balance of positive and negative feedback. The loss of balance due to resistance errors will affect the constant current output characteristics, that is, the output current will change with the load.
The error in the resistors in other circuits will only affect the value of the output current, but will not affect the output characteristics.
If the output current is large, or if the collector current and emitter current of the triode are not equal, you can replace the triode with a MOSFET.
I need to use a constant current source circuit at work. In an emergency, I found a circuit diagram and built one myself. The following is an analysis of six common constant current source circuits:
These types of circuits can obtain constant current output on the load resistor RL;
The first type is rarely used because the RL is floating;
The second type of RL is virtual land and is rarely used;
In the third type, although RL is floating, one end of RL is connected to the positive power supply terminal, which is more commonly used;
The fourth type is the positive feedback balanced type, which is popular because the load RL is grounded;
The fifth principle is the same as the fourth one, except that the current output capability is expanded. In use, people often make the resistor R2 much larger than the load RL, and omit the follower op amp;
The sixth type is the V/I conversion circuit for the ground load designed by myself;
The latter two are constant current source circuits.
![Six common constant current source circuit diagrams and analysis](http://www.eeworld.com.cn/circuit/upload/283b67701f5148866dcfe4ca5b886c5d/372bec552aaf6f1aa15290014f38a2e4.jpg)
- How to identify common mode interference? Methods to eliminate common mode interference
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the classifications of filters?
- Datasheet/Pinout/Technical Specifications of LMC555
- How to calculate the value of capacitors in parallel?
- Diode-based clipping circuit
- Structural diagram and function of sliding resistor
- Circuit diagram of a differential amplifier circuit
- H-bridge drive circuit schematic diagram and enable control and direction logic
- A single-section transistor performance test circuit
- Composite complementary symmetrical push-pull output stage circuit
- Single supply complementary symmetrical circuit
- Old 20W electronic ballast circuit diagram
- Mixing circuit
- Transistor reference basic bias circuit - fixed bias
- Precision regulated power supply circuit for UJ-1 type potentiometer
- Automatic water supply control circuit 3 for simultaneous monitoring of water tower and reservoir
