Transistor five-segment equalization circuit three
Source: InternetPublisher:蓝猫淘气 Keywords: Transistors balancing circuits amplifiers analog inductors Updated: 2020/04/20
The circuit structure is basically the same as Figure 4-33. The common amplifier and the analog inductor circuit are set up separately,
but a bias resistor is added to the transistor in the analog inductor circuit to make the circuit work more stable. The adjustment potentiometer
is connected to the feedback loop of the amplifier , and the center tap is connected to ground.
- How to adjust the bass and treble of CXA1005
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Make a pocket amplifier with 8550 and 8050
- FU-7 Tube Amplifier Homemade
- 6N5P tube direct-coupled single-ended amplifier
- LM4766 Dual 40W+40W Power Amplifier
- LM4902 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Application of BTL power amplifier circuit composed of LM3886
- Remote Sensing Powered Sensing Amplifier
- Commonly used sensing circuits
- Active load differential amplifier circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Basic Op Amp Differential Amplifier
- Parallel power op amp
- Infrared remote control transmitter/receiver circuit
- Low noise pre-equalization circuit
- Head playback equalization circuit
