Active load differential amplifier circuit diagram
Source: InternetPublisher:拳制龙 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/09/13
In order to improve the gain of the integrated operational amplifier differential input stage, its collector load resistor Rc can also be replaced by a pair of mirror constant current sources, as shown in the figure for an active collector load differential amplifier.
![200812695259960.JPG](http://www.eeworld.com.cn/circuit/upload/88cee90f7218d191a9e256f0f84fac39/560120b1498c924bf8200bbe0887e22e.jpg)
Figure Active Collector Load Differential Amplifier
VT1 and VT2 are a pair of differential amplifier tubes, and VT3 and VT4 form a mirror constant current source. Their collector potentials can all float, so Ic3 and Ic4 can change, but always remain equal. There is often a VT4 collector output, and rCE4 serves as the load of the differential amplifier. Since rCE4 is very high, the gain of the differential amplifier is also very high. In order to make the current on both sides of the differential amplifier more consistent, an improved mirror constant current source is often used as its load.
The introduction of active loads greatly improves the voltage gain at all levels, which is an important symbol of the second generation of integrated operational amplifiers.
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Transformerless AC-DC constant current LED driver circuit
- Principles and precautions of active discharge circuit
- Miniature polarity reversal power supply using MAX1721
- Boost drive circuit composed of RT8450
- Constant current charger using light emitting diode as voltage regulator
- 90V/10A high power amplifier
- Voice compressor circuit
- TDA2030A subwoofer circuit diagram
- Clamp amplifier circuit diagram
- Cascade MMIC amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Low drift peak detector
- Basic Op Amp Differential Amplifier
- An FM transmitter overvoltage protection circuit diagram
