Adjustment principle of electronic potentiometer
Source: InternetPublisher:同住地球村 Keywords: Potentiometer BSP analog switch Updated: 2020/09/27
16. From the structure of an electronic potentiometer composed of digital integrated circuits, we know that the basic working principle of an electronic potentiometer is to control the amount of resistance in the attenuation resistor network
through an analog switch , thereby adjusting the attenuation of the input signal. To achieve the purpose of controlling
the volume. As shown in Figure 4-16 (a), when the switch Ki (equivalent to an electronic analog switch) is closed and the other switches are open,
there is a short circuit between the input and the output, and the signal is output directly without attenuation; if Kz is closed, the other switches are open When ,
the relationship between output and input is: Vo (Ri+R2+R3+R4)=Vi (R2+R3+R4); similarly, if the remaining switches
are closed , the output signal will follow the above relationship. Attenuation is achieved according to the ratio of the resistor network, that is, when K3 is closed
: Vo (only i+RZ+R3 +R4)=Vj (R3+R4), etc. Obviously, in order to obtain the maximum attenuation and at the same time
have high enough resolution accuracy, it is necessary to have enough resistance levels and corresponding electronic switches. For example, to
form a two-channel electronic potentiometer with a maximum attenuation of 80dB and a resolution of 2dB, 76 analog switches are needed
. This is obviously not suitable for production using digital integrated circuits. Modern integrated circuit manufacturing technology can completely
integrate these functions into one circuit to become an electronic potentiometer
circuit with complete functions
of adjustment, counting, selection switch and resistor network .
In practical application circuits, in order to obtain the required attenuation characteristics and sufficient
resolution the minimum number of analog switches and resistors, a two-stage attenuation method is adopted. The first attenuation is 5 to 10dB, and the second is The second level uses
an attenuation of 1 to 2dB. The structural principle is shown in Figure 4-16 (b).
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- 6P3P parallel 20W power amplifier experiment
- Make a pocket amplifier with 8550 and 8050
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- Installation of electron tube differential amplifier circuit
- Make cheap speakers using waste circuit boards (TDA1013)
- Dual power supply audio power amplifier circuit using LM1875
- Audio power amplifier circuit composed of LM4835/4838
- LM4902 differential input audio amplifier circuit
- 1OW audio power amplifier circuit using UPC1238
- Homemade disinfectant circuit
- soil content measurement circuit
- Fish pond oxygenation reminder circuit
- Agricultural spraying and insecticide control circuit
- Greenhouse temperature control circuit
- Crabo oscillator circuit
- Differential Amplifier Circuit
- Voltage series negative feedback amplifier circuit
- Color display circuit
- Sawtooth wave generator circuit (1)
