Figure 4-12 is the schematic diagram of the five-speed tone selector. The analysis is as follows:
In the circuit, IC1 and other components form the electromagnetic phono equalizer amplifier, and I bar, its peripheral resistor-capacitance components and the selector switch form the tone selector
circuit .
Press the "Straight" button, sAl and SA2 will act, and SAi will move c8 in the T-shaped network in the negative feedback loop. . Rs is disconnected,
SAz short-circuit C7, the circuit becomes a typical linear amplifier, the gain is determined by (R5+R6)+3, and the output has flat
characteristics.
Press the "Language" button, SAi~SPk will move, and the positions of SAl and SA2 are the same as the "Flat" button, making the amplifier's frequency response
flat. SA3 and SA4 connect the amplifier to a band-pass filter at the input end, and the pass-band is. 200~3000Hz:,
the signal outside the frequency band is attenuated by 6dB/f audio frequency.
When the "Play" key is pressed, the action of the sculpture causes a resistor R4 to be connected in parallel to C7, slightly increasing the high and low frequencies.
When the "Orchestral" key is pressed, SA7 moves, the pins in the T-shaped network are short-circuited, C8 is grounded, and the high and low frequencies are boosted
When the "Bass" button is pressed, S:Ag and SAio move, and the switch b causes the negative feedback loop capacitors & and C to be connected in series. The treble negative
feedback is enhanced and the bass is improved. SAio connects the T-type resistor R7 to the network, so that The treble is slightly improved to balance the playing pitch and
bass.
The electronic uses 5×4 interlocking key switches.
- Using TDA2822 to do direct coupler output experiment
- Make a high-quality DAC board
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Toy electronic chicken
- 6BX7 10W bile duct amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Minimum output noise/reduced output power circuit using LM4910
- LMl876 is used to assist the audio power amplifier circuit
- LM4820-6 audio power amplifier circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- stuttering correction circuit
- soil content measurement circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Parallel crystal oscillator
- DC power supply undervoltage and overvoltage alarm circuit
- Wiring using broken wire fluorescent lamps a
- Tone selector modified from tone circuit
- tone selector circuit
- New battery charging integrated circuit AIC1761/1766 circuit
