LM4820-6 audio power amplifier circuit
Source: InternetPublisher:张小哥 Keywords: Audio Power Amplifier Updated: 2024/09/12
As shown in the figure, this is the audio power amplifier circuit of LM4820-6. After the audio signal is input, it is added to the INPUT1 terminal (pin 3) of the amplifier after Ci coupling, while the INPUT2 terminal (pin 4) of the amplifier is not connected, and the amplified signal is output from pins 5 and 8. A load such as a speaker is connected between pins 5 and 8 to form a power amplifier circuit. There are two amplifiers inside LM4820-6, and there are two 25kΩ resistors inside to set the closed-loop gain. The circuit gain of Amp A1 and Amp A2 is 1; the differential output gain Av=2Rf/Ri.
- Using TDA2822 to do direct coupler output experiment
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- A simple and practical tube amplifier
- Audio power amplifier circuit powered by a single power supply using LM1875
- LM4902 differential input audio amplifier circuit
- 1OW audio power amplifier circuit using UPC1238
- 2W×2 power amplifier circuit using LM1877
- LM4915 is used for dual-channel amplifier circuit
- Typical laptop audio power amplifier integrated circuit
- Auxiliary audio power amplifier circuit design based on LM4730
- Two-channel high-fidelity power amplifier integrated circuit
- Two-channel audio power amplifier integrated circuit
- Integrated circuit audio power amplifier circuit
- Audio power amplifier circuit using TA8216A chip
- Two-channel audio power amplifier circuit
- Mono audio power amplifier circuit
- 20W (10W×2) audio power amplifier circuit using TDA2005S
- LM388 audio power amplifier circuit
