Tone circuit with high, mid and bass functions
Source: InternetPublisher:张小哥 Keywords: BSP tone control circuit Updated: 2021/05/08
Figure 4-7 is a tone control circuit designed and calculated using the relationship obtained from the above analysis , in which Ai is a buffer amplifier stage to reduce the burden on the front-stage output. The low-frequency turning frequency of this circuit is 30Hz, the high-frequency turning frequency is 1kHz, and the control range is ±20dBo. Using an operational amplifier can not only design a tone circuit with high and low bass control functions, but also design a tone control with high, medium and bass control functions. circuit.
- Tutorial on making a MIDI arpeggio synthesizer
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Preamplifier made of 6P15 tube
- 18-inch large speaker
- 6AS7 tube amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- A very simple amplifier
- Class A power amplifier circuit with an output power of 18W
- Tube single-ended class A 300B power amplifier circuit
- Smoking Cessation Circuit
- Inpatient pager circuit
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Poultry warming temperature control circuit
- common emitter amplifier circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
- Guest arrival signal recognition circuit
