color discrimination circuit
Source: InternetPublisher:风向双子座 Keywords: BSP sensor Updated: 2020/10/27
It is a measurement method that accurately identifies the three primary colors. The principle is based on the wavelength characteristics of the three primary colors (
different
wavelengths, peaks, and positions).
With the help of the peak wavelength color filter and photosensitive diode
, the spectral sensitivity covers the entire visible light range, and
the X, Y, Z of Figure 11-26 is output, and then
undergoes U4A, U4B:_fU4C for A/D Convert to get
the final results of red-yellow, green-blue and purple.
In the actual use of color sensors , the most important issues are the lighting power supply and light condensing system, and the area of the color discrimination element should be as small as possible in order to effectively form an illumination
point
on the object . It is most convenient to use incandescent lamps as the light source. As for the light system, attention must be paid to the focal length of the light mirror and
the diameter of the illumination point.
The color sensors currently on the market are relatively expensive. They are used to identify lines and strips in robot production and competitions. From a practical point
of view, infrared photoelectric reflective sensors can also meet the usage requirements.
- What does a rectifier do? What is the process of rectification?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- In-depth analysis of energy losses in oscillation frequencies
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Star finder battery indicator circuit
- An example of proportional integral circuit diagram
- Excellent performance household inverter power supply circuit
- Inpatient pager circuit
- Physiotherapy ventilator circuit
- Rural fish farming control circuit
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Color display circuit
- Power phase sequence display circuit
- Various signal generator circuits
- Small current generator circuit
